Momentary Footswitch that Doesn't Snap
Started by stevenpcharles, April 01, 2018, 07:30:51 AM
stevenpcharles
Hi All,
Does anyone know where I can find a momentary SPDT or DPDT footswitch that doesn't snap?  I purchased two recently and both while momentary switches, they both snap at the bottom of the travel to activate the switch. When you remove your foot it releases. But that initial snap when you press is annoying. I know they make them because several of my commercial pedals have momentary switches that don't snap, but I cannot seem to find a vendor out there that explains this.
One vendor said this was a "normal" and expected thing from a momentary footswitch, which was the first time I'd ever heard that.
Any thoughts?
Steve
Sounds like your "normal vendor" has gone through life only ever encountering these:
But he's been missing out on these:
The first ones click; the second do not.  Both pictures are from Tayda.  They have a discount coupon ("GIZMO") active right now, btw.
Edit: I just re-read what you wrote.  You asked for changeover switches.  The one I posted was a simple push-to-make.  My bad.   :-\
...of course you could use the SPST switch above and the Boss/Ibanez switching circuit* to do the changeover?
___
*Article courtesy of R.G. @ GEOFEX
I've an 'x-wing' double throw that does click but it's a far less noticeable event then that of the Alpha style.
Could the alpha be opened up and modified to eliminate the 'click'?
dave
