V3207 in eagle
Started by Kipper4, February 07, 2020, 04:50:58 AM
Any of the common used librarys contain the BBD part V3207 ?
Or can i make my own? if so how?
thanks
temol
You can use generic DIL-8 package on a schematic. Check the "ic-packages" library. There is also MN3007 available in Madrean's library, but you have to check datasheets if the pinout is the same.
T.
Thats what I did. used the madbean MN3007 (same pinout except for the power supply rails) and relabelled. Thanks temol.
It'll do for now.
