Darkglass Microtubes B3K debug
Started by guidoilieff, May 15, 2018, 03:06:19 AM
guidoilieff
1.Name of the project: Darkglass Microtubes B3K debug
2.Links to the source of the project: http://effectslayouts.blogspot.com.ar/2018/05/darkglass-microtubes-b3k.html
3. (i'll try to upload pictures)
4. I tried j112,mpf102 and bf245a. Replaced 22nf capacitors for 33nf. Replaced 1uf capacitors for 2 680nf in parallel both times, 200k resistor (t2 Source) for 220k.
6.What it does and does not do how it works: Blend pot works, the dry signal is ok but volume drop in the wet signal A LOT. An electric bass don't make any sound after the first 1M resistor but an amplified signal does. It's not distorted and sound like I have my finger on the input or there is a ground disconnected, that kind of hum depending on the switching and pretty loud. Also  sounds very tiny (no bass).
Tried different transistors in all combinations possible.
I can't hear anything on the input of the first tl072 (pin 2 and 3) but in the output (pin 1) is that annoying sound I described for the rest of the circuit.
Voltages:
T1
G 0
S 2.4
D 4.7
T2
G 4.2
S 4.7
D 9
4049UBE
pin1 6 v+
pin2 2
pin3 2
pin4 6
pin5 0
pin6 6
pin7 0
pin8 0 gnd
pin9 0
pin10 6
pin11 0
pin12 6
pin13 0
pin14 0
pin15 6
pin16 0
I don't know if Im missing any info.
Thanks for your time.
anotherjim
Can't tell much without a schematic. Do you have a link.
Some things I can see...
If T1 is an amplifier, it's probably ok.
If T2 is a buffer, it's probably ok.
If only one inverter in the 4049 is used as an amplifier (pin 2&3), it's probably ok.
guidoilieff
Quote from: anotherjim on May 15, 2018, 04:37:48 AM
http://guitar-gear.ru/forum/index.php?app=core&module=attach&section=attach&attach_id=29146 I think this will work and here is another one https://4.bp.blogspot.com/-AncwI2iyg2g/WM-9dFGc_cI/AAAAAAAAElo/JPPhsPyjavcasyIfRYj_0IRIf1cjaGBTgCEw/s1600/b3k.png
I don't know on which schematic its based on.
anotherjim
Let's say it's this one...
So there are those TL072's we don't have measurements for.
BTW, if you have it plugged into a high impedance amplifier, it's possible for some signal to sneak through circuits that actually have no power. It's also possible to get audio that's weak/noisy if the instrument input jack wiring has a problem.
You should expect to get good audio on all pins except power & ground of the first TL072 and the DC bias on the pins should be 1/2 of the 9v supply from VR connections.
guidoilieff
#4
Quote from: anotherjim on May 15, 2018, 01:25:45 PM
Oh yeah, sorry. Forgot to mention that all tl072 voltages are ok. Also audio jacks are ok and I tried on 2 different pc speakers.
Here it is the schematic that its based on
I'm trying to understand the path of the input signal.... the audio splits from pin 6 and 7 to the blend pot and the gate of the first transistor right?
Sorry if i'm being a little bit messy with my info and my english...
KarenColumbo
The ...org Link you posted is jumbled.
I see something of myself in everyone / Just at this moment of the world / As snow gathers like bolts of lace / Waltzing on a ballroom girl" - Joni Mitchell - "Hejira"
Quote from: KarenColumbo on May 16, 2018, 05:08:26 AM
The link is at "the other place".  You'll have to fill in the blanks yourself.
KarenColumbo
#7
Ah, that one. Always forgetting it's an .org place. Btw: I'm building a b3k at the moment - for a friend. Will try these schems out tomorrow/day after tomorrow.
guidoilieff
let me fix that
you'll have to download the image for full res
guidoilieff
Does this help? A video will help? what should I do now?
