DIYstompboxes.com
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
|HOME|
|DIY FAQ|
|GEO FAQ|
|Debugging Page|
|Links|
|Schematics|
|Wiki|
|Layouts Gallery|
|STORE|
|AMPAGE|
|GEOFEX|
|AMZ|
Home
Help
Login
Register
DIYstompboxes.com
Projects
Beginner Project
CryBaby GCB95 True Bypass With DPDT Switch
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: CryBaby GCB95 True Bypass With DPDT Switch (Read 1818 times)
ekavcik
member
Total likes: 0
on:
May 17, 2018, 07:51:47 AM »
Guys, have a problem with truebypass mod. My GCB95's original switch (3 leg spdt) broken some how... It wasn't go bypass and wah effect was staying always on. I have to say this; wah function was still working. So I wanted to change switch (6 leg dpdt) and a truebypass mod. I followed these steps;
Canceled the connection between input and buffer like this;
http://media.stinkfoot.se/2010/11/pcb1.jpg
Made a new circuit like this
http://media.stinkfoot.se/2010/11/pcb2.jpg
Finally wired like this
http://imgim.com/d49055d9-8d1d-4f7c-afbc-4ab48ecaa526.png
So, i failed somewhere
Pedal can go bypass now, but when i switch on, there is no signal. Only a very weak signal when i %100 push down.
Please help, best regards
Efe
Logged
Elijah-Baley
Awesome!
Total likes: 175
Re: CryBaby GCB95 True Bypass With DPDT Switch
Reply #1 on:
May 17, 2018, 10:28:55 AM »
I can't get what you drawn, I'm sorry.
But try to follow this layout:
Because you have a DPDT switch I guess it's enough to ignore the third column of lugs of the 3PDT footswitch (9v negative, resistor + LED).
Logged
Print
Pages: [
1
Go Up
« previous
next »
DIYstompboxes.com
Projects
Beginner Project
