Help with A/B/Y Splitter Schematic
Started by chuck shakesy, May 22, 2018, 05:07:59 AM
chuck shakesy
Hey all, first time poster here, literally registered because I didn't know anyone I could ask about this, I've made a couple basic PCB kits in my time, but this is my first time trying to go from scratch with something.
I want to basically build a splitter where each output has it's own on/off footswitch and LED.
I was wondering if I'm on the right track, and what adjustments I need to make to anything.
Also wondering if I need to ground the input and output jacks to the powered ground going back into the battery or something else entirely?
Thanks in advance  :)
Welcome to the board.
Although the thread title says ABY im not sure you want the Y.
So heres a diagram of an AB with indicator leds
https://i.pinimg.com/736x/33/11/e8/3311e849256f783ea83211d4181a2061--guitar-parts-guitar-building.jpg
chuck shakesy
Quote from: Kipper4 on May 22, 2018, 05:59:55 AM
Thanks a heap, but I am going to be using both at once at times, it's basically so I can run one of the outputs into an octave down, a string and use it as essentially a bass from time to time.
