Author Topic: Is my 3pdt causing a pause in switching?  (Read 646 times)
Joncaster
« on: July 03, 2018, 08:20:13 AM »
Hey,
So boxed up a Rangemaster sorta thing, and it all works fine,
But there is a delay between On and Off. Like a short pause where there's no sound.
I had that once with a DPDT taken from an old Vox reverb toggle, and I figured it was On/Off/On.
Is the fairly cheap 3PDT possibly on/off/on? In said it was on/on when ordered, so maybe they left the 'off' part out.
Just wanted to check if that's the usual cause before I unsolder it and put in a better one.
Music is Eternity: stretched like the sky over the landscape of our lives.
"It's better to be looking at it, than looking for it."
My Band:
http://www.coldwatermorning.bandcamp.com
mth5044
Re: Is my 3pdt causing a pause in switching?
« Reply #1 on: July 03, 2018, 09:32:35 AM »
Is it a stomp or a toggle? As far as I know, the mechanical action of a stomp doesnít let you have a third state, or center off, itís either one way or the other.
Could be a bad switch.
Does it happen when your engaging and disengaging the effect? Have you wired the power to go on/off with the switch for some reason?
Joncaster
« Reply #2 on: July 03, 2018, 10:00:53 AM »
Sorry, it wasn't the switch at all, it was me being stupid.
I completely didn't put the output cap in :icon_rolleyes:
It was off-board, and I wired the thing up after a long hiatus, forgot all about it.
So now it is completed!
My Band:
