Negative Power
Started by Nobisayzhoi, July 20, 2018, 02:07:22 PM
Nobisayzhoi
The Schematic that I'm using to build a Pedal shows this for the power. I takes negative power and I'm wondering how to Wire that with a 9v DC jack.
Kevin Mitchell
You wire the DC jack just the same. Just make sure the power connections go to proper place in the circuit - whether you're bread boarding or assembling a PCB.
Keep in mind that you can't share this power supply with other pedals unless they also run positive ground.
This hobby will be the deaf of me
Quote from: Kevin Mitchell on July 20, 2018, 04:29:17 PM
+1 THAT!!
Do something that makes this basically impossible for you to do, otherwise on some occasion in the future it *will* occur and you *will* feel like a complete nitwit.
