Author Topic: Reckless compressor - an original feed-forward diode based compressor  (Read 6702 times)
pinkjimiphoton
  • Total likes: 940
  • High priest, Cult of Germanium, and Dudeist Monk
    • odds are i'm probably banned  here...
Re: Reckless compressor - an original feed-forward diode based compressor
« Reply #40 on: February 14, 2019, 10:22:20 AM »
jang;enbox is an mxr dynacomp with a switch for the high end snubber in and out. noisier, but more of a treble boost . jim ....err... roger mcguinn does use them, or at least did endorsements for a while. but nothing as cool as an extra eq or treble boost circuit, just undoing one component on the mxr.
i believe the second series may have been a slightly different circuit with a couple more options.
listen loud. blaze one first:
https://drive.google.com/open?id=0BzMJxNNgY3_yc0JNd0VqdmNIWEk
I stand for Truth, Justice, and the American Way. @#$% TRUMP! YOU ARE EITHER ANTI FASCIST, OR YOU ARE ONE. #BLM
#FuzzyGoodness
Ben N
  • Total likes: 374
  • Ben N. - really! Now Israel, once Baltimore
« Reply #41 on: June 13, 2019, 09:08:38 AM »
Just want to report that my Reckless Comp (Rev B) on pcb supplied by Jonny is at long last done, and it is instantly my "main squeeze" for clean, better sounding and quieter than my old Dyna even at high compression settings. Loves a Strat. Sorry no pics, both because my phone camera died, and because I butchered the pretty powder coating on my 125B (tight fit with top mounted jacks) with a runaway drill bit. Eventually I'll figure out a way to rehab the finish, but in the meantime I'm playing it, and loving it. Thanks, Jonny.
andy-h-h
« Reply #42 on: June 27, 2019, 12:18:56 AM »
I just made a vero for the Rev 4B if anyone is interested.   Sitting over on Guitar FX Layouts in the forum (unverified section).   It does however work, as I just finished making one.
jonny.reckless
« Reply #43 on: June 27, 2019, 02:51:54 AM »
I couldn't find the layout - can you post a link please?
andy-h-h
« Reply #44 on: June 27, 2019, 04:32:04 AM »
Sure - hope you don't mind me making the vero.  I did credit you  :icon_biggrin:
http://guitar-fx-layouts.42897.x6.nabble.com/file/n46845/Reckless_Diode_Compressor_Rev_B4.png
« Last Edit: June 27, 2019, 04:34:43 AM by andy-h-h »
snk
« Reply #45 on: June 27, 2019, 08:45:10 AM »
Thank you, Andy.
Is this design a "typical guitar comp" (aiming at long sustain), or can it be used like a "regular" eq ?
andy-h-h
« Reply #46 on: June 27, 2019, 08:56:14 AM »
Thank you, Andy.
This is definitely not EQ, and for the record, it's not my design.  I just did a vero layout for Jonny's design as I liked the sound of the demo.  If you want EQ, try a preamp of some description.   :icon_smile:
snk
« Reply #47 on: June 27, 2019, 09:33:13 AM »
Oops, sorry, the last word was definitively a mistake on my side  :icon_redface:
I meant : "is this designed as a "guitar comp" (aimed at increasing sustain, with a limited bandwidth), or can it be used like a "regular studio comp" on bass, drums, full mixes, etc. (if we add pots for attack and relase) ?
andy-h-h
« Reply #48 on: June 27, 2019, 05:39:25 PM »
Hey snk,
It was designed by Jonny Reckless for guitar, and while I have not tried it on anything other than guitar as I only built one yesterday, I'm guessing it will not be very effective on drums / vocals etc.
Reason being - If you try to use this as an insert on a channel, or plug anything other than a guitar or bass into this, you will most likely run into level and impedance issues.  Running at 9v restricts dynamic range too.
If you want something for studio work, I'd say run with proper rack-mount gear or some nice plugins.  :icon_wink:  As far as studio grade compressors go, I'm yet to find a cheap way of getting there.
jonny.reckless
« Reply #49 on: June 28, 2019, 12:21:33 PM »
I doubt it would be much good as a studio compressor. Typically you would want separate controls for threshold, ratio, attack and release, and some way of doing stereo linking of the sidechain for studio use. It was designed specifically for electric guitar, although I have tested it with bass and acoustic guitar and it works pretty well for those purposes. There is no EQ - the circuit has a flat frequency response. It's a feed-forward architecture with a peak detecting sidechain.
I just thought it would be fun to see if I could make a diode compressor actually work  :icon_cool:
forsakenrider
« Reply #51 on: October 02, 2019, 11:36:42 PM »
Hot jam this is cool! I'll need to build one of these, sent a PM about PCB's
Ben N
  • Total likes: 374
« Reply #52 on: October 03, 2019, 04:34:17 AM »
Just wanted to add that I just started using the Reckless Comp as a lead boost into the front end of an ODR-1 clone (Aion Andromeda pcb--big thumbs up for that, too, BTW) set for light-medium rhythm OD, and it's fantastic for this, too, and a more subtle alternative to eq-type boosts. I generally have the compression set between 11-12 o'clock, and the level just audibly above unity, which works both for a clean rhythm setting and as a punchy lead boost, adding a little bit of sing and sustain without being overbearing or changing the tone obnoxiously. Honestly, I can't say enough about this thing. I've got a THAT4301 in the queue for a more bells-and-whistles, super-controllable, anywhere in the signal chain compressor project, but for a simple 2-knob comp, tonally neutral, that just does the job and sounds good, no, great, somewhere in the Dyna-Ross sonic spectrum, without annoying sickly compression artifacts, this is hard to beat.
« Last Edit: October 03, 2019, 04:35:57 AM by Ben N »
« Reply #53 on: October 03, 2019, 06:10:47 AM »
  :icon_cool: :icon_lol:
"There is a pestilence upon this land. Nothing is sacred. Even those who arrange and design shrubberies are under considerable economic stress in this period in history." --Roger the Shrubber
Ben N
  • Total likes: 374
« Reply #54 on: October 03, 2019, 09:37:07 AM »
Exactly, but without the nasally upper-mid emphasis. :D
snk
« Reply #55 on: February 11, 2020, 11:35:04 AM »
Hi,
I am building this compressor, using the veroboard layout posted by Andy above.
Thank you for the great design !
A couple questions :
- Will the Reckless Comp work fine with a bass, or should I tweak a couple values (like the input cap, etc) ?
- Is there an easy way to add a gain reduction indicator led ?
- I do not have any BC556B transistor : is there any alternative giving similar results ?
- Which kind of capacitors are suggested for the two 100nF caps ? green Mylar/box, or ceramic ?
« Last Edit: February 11, 2020, 03:35:07 PM by snk »
« Reply #56 on: February 11, 2020, 12:10:11 PM »
The music is from my band Saint Wry: https://open.spotify.com/album/76AYXUusxuLu0GiVGBQn6q
Really wanted to hear, but Spotify's not available in my country.  :o
50 pedals and counting!
Ben N
  • Total likes: 374
« Reply #57 on: February 11, 2020, 05:05:30 PM »
Going through intense withdrawal -- my Reckless comp crapped out. I haven't had a chance to do any trouble-shooting, other than to check that it isn't anything stupid or easy, like an I/O short (bypass works) or power issue (LED lights). When I dig in, I'll report back.
I suspect this may have something to do with whatever it was killed my Vox MV50AC at the sametime (and that one I can't really troubleshoot or fix, and Korg refuses to do either. Grrrrr.)
jonny.reckless
« Reply #58 on: February 11, 2020, 08:51:51 PM »
Ben, which revision did you have? I can take a look and see if I have a spare PCB in my drawer somewhere.
jonny.reckless
« Reply #59 on: February 11, 2020, 08:58:52 PM »
It should be OK for bass. Certainly for passive bass.
A small high sensitivity LED in series between R14 and the diode bridge would light up under heavy gain reduction.
Yes a 2N3906 or generally any small signal PNP should be OK.
I used 5mm pitch 50V ceramic caps. I think they are 10% X7R but it's not super critical.
« Last Edit: February 11, 2020, 09:06:02 PM by jonny.reckless »
