Boss SD1 help
Started by primus299, July 22, 2018, 03:28:49 AM
primus299
I did the mods on a Boss SD-1 overdrive [chocolate mod], from the book "How to Modify effects, for maximum tone" by Brian Wampler. Upon completing the mod, I ran into a odd problem. It began to stutter. I've included a short video to better understand what is going on.
For the video: I play single notes from 1-10 seconds. Then, after 10 seconds mark, I play a few power chords. It sounds messy, choppy, and it stutters.
A side note, I did feel like I scratched the R2 when I pulled out the cap that was next to it. Would this be a cause of the stuttering?
welcome to the forum. I think C4 has a hole thru its outer cover. maybe replace that - I can't see any damage on your noted resistor.
intripped
#2
let's see the solder side, also  ;)
PS: D5 and D6 are correctly oriented, but in the pic i can't see the flat spot (see image) of the LED in D4; perhaps it's ok, but check the correct orientation.
primus299
I just took some pics today of the board on both sides.
I didn't notice the slight damage (solder iron contact) on the C4 cap until just now.
The R2 has a bit of the tan paint chipped off from the razor blade (to remove glue).
