Weird transformer
Started by guidoilieff, August 06, 2018, 10:56:56 PM
MISTAKE!!!
Do NOT cut jumper 173!!
The drawing is right, my text was wrong.
guidoilieff
Quote from: PRR on August 11, 2018, 09:42:44 PM
MISTAKE!!!
That's fine. Thanks for the warning!
It works!!
guidoilieff
Quote from: PRR on August 10, 2018, 07:23:39 PM
Yes.
EDIT!!!   Cut jumpers JW172 JW173 JW174.
EDIT!!!  Do NOT cut jumper 173!!
Feed 0.5V signal: L to JW175, Gnd to JW176, R to JW177
Hey, im sorry. I said its working because the ic got warm (37/38 centigrades) and when I discharged the capacitors it made a big spark but now when I connected a speaker nothing happened.
I plugged the fan to check if the amp was on without a power button but its not.
Do you think the problem may be that I have no way to switch it on like this?
this is what I found on page 70:
7-25. IC PIN FUNCTIONS
IC501 MASTER CONTROL (M306622 MA-A01FP)
Pin No.  Pin Name         I/O   Function
1          STK-MUTE        O      Power amp ON/OFF signal output
2          POWER            O      Power ON/OFF signal output
3          F-RELAY           O      Front speaker relay control output
(manual: http://diagramas.diagramasde.com/audio/Sony_HCD-GRX80_RXD8.pdf )
guidoilieff
Yes.
I'm sorry to insist but do you think it will have trouble powering on? Thanks
