Building a slapback delay
Started by ljudsystem, August 24, 2018, 02:52:01 AM
ljudsystem
I've got an old Dano Reel Echo that i only use for slapback (one repeat around 100 ms and a bit of warble). It sounds good but its a beast. It takes up half my pedalboard!  :icon_eek: So i'm thinking i'll build something that takes up less space. Preferably 1590B sized.
I'm thinking either the Deep Blue Delay with the profundis lfo but i'm unsure if it will fit in a 1590b box.
Could the Small Angel Chorus be modded to work as a slapback delay by changing the pin 6 resistor?
Quote from: ljudsystem on August 24, 2018, 02:52:01 AM
That's a reasonable thought. Whether it fit a 1590B, I don't know.
Yes, it'd be easy to mod for a slightly longer delay. It's *almost* there already.
HTH,
Tom
ilcaccillo
Hello ljudsystem,
I had the same needs as you, let me just tell you before you take your time to build something that the Danelectro BLT slap echo pedal does exactely what you need and sounds pretty good.
It's a pretty inexpensive pedal and it would save you time and money in building something.
You can get one for really cheap from ebay
Danelectro DJ-3C BLT Echo Mini Effects
https://www.amazon.com/Danelectro-DJ-3C-Echo-Effects-Pedal/dp/B0002D03B6/ref=cm_cr_arp_d_product_top?ie=UTF8
thermionix
If you want analog, for CHEAP, there's the Behringer VD400.  No modulation though.
ljudsystem
Modulation is important to me, I need a bit of tape wobble. The BLT doesn't have modulation either, right?
Could I change the 10k resistor going from pin 14 to the 0.1uF cap to a pot to make a mix control?
Danich_ivanov
I have no experience with pt2399 chips, but i'm pretty sure that you can combine Lfo section from chorus with the rest being deep blue delay. Again, I don't know exactly, but I see that chorus Lfo is hooked up to the pin 2 of the chip, where in deep blue delay you have a fixed cap, and first thing that comes to mind is build a deep blue delay, replace fixed cap with lfo from chorus, and see if it flies. If it does, I would use a single, dual channel IC for lfo and input section of Deep blue delay, and replace it's output section (being opamp) with some sort of a transistor (jfet possibly?) based gain stage, tillman preamp for example.
merkaleli
Try Valve Wizard Equinox II. It's not a real reverb effect but, does a slapback effect.
Quote from: Danich_ivanov on August 27, 2018, 07:48:04 AM
Yeah, this is a good idea. Take whatever delay circuit you like, then add the Little Angel LFO and feed it to pin 2.
thermionix
Quote from: ljudsystem on August 27, 2018, 05:46:50 AM
I'm surprised it's audible in a quick slap-back.
ljudsystem
Well, it's subtle but still audible.
ljudsystem
Thermionix, you're right. I played around with the reel echo and the modulation is not really audialble at the slapback setting.
Guess I'll just build the deep blue delay then.
