Phase 90 - adding MIX knob and output buffer [CLICKBAIT: pedal finish inside!]
Started by madros, August 26, 2018, 03:50:21 PM
madros
Hello everyone!
It's my first post here so I hope I won't violate any writen or spoken rule. ;)
Back to the topic. Some time ago I bought a DIY kit for MXR Phase 90 because I've always liked its sound the best among all the other phasers, but for me it was lacking some knobs and options. I like to have some spare knobs and switches that I will never use once I set them the very first time I try a new pedal, so it was clear that I need to make some mods. R28 and vibrato was obvious ones and easy to manage, but I've also tried DEPTH knob, MIX knob and adding an output buffer. Well, I dont know if I managed to get first three of them right, but I actually like how they sound. To be honest DEPTH knob sound more like wave shaping (slope, wave skewness etc.), but hey - it sounds neat.
The real problems start with MIX and buffer.
First of all - tweaking MIX knob does not change sound at all. What did i do wrong? Should I go for potentiometer instead of R15?
Secondly - adding the buffer. I have followed Craig Anderton's 741 opamp buffer design but obviously I messed something up. The pedal itself works great, but when I turn buffer on (I can do that with an internal switch) all the sound just get sucked in. Im linking output of the P90 circuit with the input of the buffer one.
Can you please tell me where did I go wrong?
For real size please see: https://i.imgur.com/aUzhZxJ.png
List of elements
R0 1M
R1 10k
R2 470k
R3 10k
R4 10k
R5 24k
R6 10k
R7 10k
R8 24k
R9 10k
R10 10k
R11 24k
R12 10k
R13 10k
R14 24k
R15 150k
R16 150k
R17 270k
R18 56k
R19 150k
R20 3M9
R21 150k
R22 150k
R23 470k
R24 10k
R25 1M
R26 4k7
RV1 C500k
RV2 Tr.200k
C1 10n
C2 47n
C3 47n
C4 47n
C5 47n
C6 47n
C7 10n
C8 15u
C9 47u
C10 22u
C11 47n
D1 1N400X
D2 1N914
D3 5v1
Q1 2n5952
Q2 2n5952
Q3 2n5952
Q4 2n5952
Q5 BC560
U1 741
U2 741
U3 741
U4 741
U5 741
U6 741
The purple one is INPUT, and I did cut the cooper lines under 741 IC.
Just to draw you attention and provide something pleasant for your eyes - this is how this whole thing looks. :)
anotherjim
Andertons circuit uses dual + & - polarity supplies, which is why the 1M resistor on the 741 +input goes to ground. You need something like the MXR U1 where the resistor goes to some voltage close to half of the + supply voltage. If the buffer is in the same box, you can use the same supply from that 5v1 zener D3. Note that the MXR U1 is also a buffer and essentially the same circuit as the Anderton.
...and yes, that is a sweet looking pedal.
madros
Thank you very much for your advice.
I have tried connecting 4.5V from the Zenner diode to the Andertons' circuit and I managed to get some sound (it felt to me as it was boosted a little), but only when I am hitting string really really hard.
Does that mean that the Voltage is still too low? Or should I remove/change any caps or resistors? To be honest I don't know much about op-amps so I don't really know where to tweak.
thomasha
I think there is something missing there... like an output cap and a reference to ground.
Take a look at the micro amp.
https://www.electrosmash.com/mxr-microamp
it has the 4.5v reference through a 10M resistor, it has an output cap and a reference to ground of 10k, you can use a pot here and see how much you need. Just ignore the stuff at the top, because you're probably looking for a buffer with unity gain, right?
In my build I changed one of the resistors at the final transistor stage. It already had a lot of gain just waiting to be used. So, there was no audible volume drop.
