Stag3 a boost from guitarpcb
Started by whomeno, September 03, 2018, 01:41:31 AM
whomeno
I had built this one a few months ago. I did a rebuild on it. they call for a j113 trans. or a j201 is there any others that would give a little more boost?
Not sure how to tell by the data sheets
Gear as of now
Gibson 2017 Les Paul Tribute T
Epiphone Les paul Special (upgraded)
Marshall DSL 20 Head
Peavy Valve king 20 W
2 X 12 Cabinet with celestion vintage 30 & celestion G12T-75
And a lot of pedals
antonis
It's called "Transconductance" (gm) or "Forward transfer conductance" (gfs) but I'm not sure if you'll manage to get more gain due to wide parameter spread, even among identical JFET types, in conjunction with small parameter variation among different JFET types..
(e.g. type X JFET may exhibit gm of 4 - 6 mhos where type Y JFET may exhibit gm of 3 - 5 mhos - you can easily choose type X for more gain and result in less gain in case of type X has an actual gm of 4 mhos where type Y had an actual gm of 5mhos..)
For a little more gain it should be helpful to raise a bit Drain resistor value.. :icon_wink:
(without significantly upsetting bias..)
P.S.
The above stand for grounded Source amp - if there is a Source resistor, you have to tweak RDrain/RSource ratio..
