2sk246 for Aion Prism FA-1
Started by cnspedalbuilder, September 03, 2018, 02:20:09 PM
cnspedalbuilder
Hello, I'm building the FA-1 FET preamp and have it all set except that I do not have the 2sk246. Can I substitute a J201 in that circuit without any other mods?
I tested it w/the J201 and it didn't work but I made some compromises for testing before boxing it up--soldered the pots weakly (for testing before boxing) and I connected lugs for an external switch w/jumpers instead of installing switch. So if you think it'll work w/J201 I'll try again.
If not, would anyone have one to buy? I know you can get it online, but I'm $6.50 with shipping is a bit much for one transistor.
That plan is not fussy. Nearly any JFET will work.
smallbearelec
Quote from: cnspedalbuilder on September 03, 2018, 02:20:09 PM
When you tried the J201, did you account for the different pinout? If not, see the drawings in Figure 17 of this article:
http://diy.smallbearelec.com/HowTos/BreadboardICDist/ICDist.htm
You can either bend leads of a J201 to put the gate in the center, or find locally a common JFET that has that pinout. The 2N3819 is a possibility.
cnspedalbuilder
Yes, I did. I am about 97% sure that my J201s are fake, normal NPNs. I don't know where I got them, but I ended up ordering the 2sk and it worked perfectly.
