Noisey A/B Switch
Started by eskimoquinn, September 12, 2018, 02:32:50 PM
eskimoquinn
I just wired up an A/B Switch to switch between two guitars according to the diagram below. However, when the power is plugged in, it is extremely noisey. It is almost dead silent when no power. It looks like I have good working connections as evidenced by a good signal when no power, but the DC is somehow leaking into the audio path. Any thought on what might be causing this:
Can we see pictures of your build please? ;D
eskimoquinn
Hiss? Or buzz?
If buzz: quality pedal power supply? Or some old wart from the junk drawer?
eskimoquinn
Definitely a not a hiss. I am using a voodoo labs power supply which causes no issues with other pedals.
BetterOffShred
Make sure the grounds are all good, double check all your wiring, and then make sure it isn't the switch.   There's not really a whole lot to go wrong in this build.
stallik
Quick look but the led ground appears to be running to the jack ground. Try running it to the 9v negative instead
eskimoquinn
Not sure I follow. 9v negative? 9v battery? No battery in this one.
He's talking about the negative terminal of the power jack. There's no reason to connect power ground and audio ground in a completely passive box.
eskimoquinn
I see, so complete n00b question, the negative of the jack should go to where? in other words, how would the schematic I posted changed if I followed this suggestion?
BetterOffShred
It only has power to illuminate the switching LEDs ..  the actual jack switching just has grounds straight across from the ring lugs on the jacks there.
ayayay!
I love and miss Dano but he got it wrong on that one.  Replicate this on the LED wiring x2 to make it work correctly, with the other LED going to the spare lug.  :)
The people who work for a living are now outnumbered by those who vote for a living.
stallik
Thats it Jono, and as it's an A/B, another LED can be attached to the same + but run to the other side of the switch.
Resistors can be adjusted to make both burn at the same visual brightness
