Looking to build a tube pre amp/overdrive need suggestions
Started by whomeno, September 17, 2018, 10:11:27 AM
whomeno
I want to put a real tube pre amp overdrive in front of my boss kantana. I have the vt999 now, but looking for for some thing better.
What would be a good pedal to build?
Gear as of now
Gibson 2017 Les Paul Tribute T
Epiphone Les paul Special (upgraded)
Marshall DSL 20 Head
Peavy Valve king 20 W
2 X 12 Cabinet with celestion vintage 30 & celestion G12T-75
And a lot of pedals
Depends on what kind of tone you're after. The Alembic F2-B will always be a popular pick, based on a Fender front end. If you're looking for something with a bit more balls I've become a fan of the Soldano Supercharger GTO, goes from little grit to full-blown high gain mayhem.
Or if you're looking for something nice and simple, hard to go wrong with a Matsumin Valvecaster 8)
Marcos - Munky
Bear in mind tube circuits usually works in high voltages. A high voltage shock will surely hurt you a bit, if not worse. It's not telling you to not build a tube circuit, just telling you to be careful.
Quote from: Marcos - Munky on September 17, 2018, 11:32:23 AM
+1
That's one of the big draws of the Valvecaster, it can run on 9V ;D
printer2
Easy enough generating a voltage more than 9V to run a tube, now days there is no reason to limit yourself to anemic tone coming from a tube on low voltage.
Fred
Quote from: printer2 on September 17, 2018, 03:09:49 PM
Tone is subjective, but I've never thought the Valvecaster sounded anemic. That's part of why it's such a popular build in my opinion. Low parts count, dead simple to build, runs off 9V, won't kill you if you mess it up, and frankly sounds very good.
whomeno
I looked at the Valvecaster, but he said it was based for a single coil pick up. I'm looking for one to run humbuckers through.
what i want to do is run fuzz pedal then tube preamp to amp
Gear as of now
And a lot of pedals
Marcos - Munky
I use the valvecaster with a humbucker pickup. It sounds amazing. Mine have a gain knob, volume knob, no tone knob. Also, be sure to use a 12AU7, a 12AX7 sounds ok in a valvecaster but the 12AU7 sounds way better.
In Nathan's words:
Quote from: vigilante397 on September 17, 2018, 03:18:11 PM
Yeah, it's pretty easy to get a high voltage from 9V. Just need to be careful when working with, let's say, 200V. But it's pretty doable. Like I said, not telling to not build, just telling to be careful.
Quote from: Marcos - Munky on September 18, 2018, 01:30:51 AM
Same. Every guitar I own has humbuckers because that's the sound I like, and humbuckers sound great with the Valvecaster.
+1.
An old rule in tube work is to use Mu lower than B+. This is another way of saying there is +/-1V uncertainty in tube bias due to "contact potential".
Mu of 12AX7 is 100 and it can be hard to get working for B+ much under 100V.
Mu of 12AU7 is 20 which is a lot closer to our 9V-12V B+.
(Few miniature tubes have Mu as low as 9.)
whomeno
Gear as of now
And a lot of pedals
12AX7's are going for stupid money these days, so some alternatives would be the 12AV6 / 12AT6 / 6AV6 / 6AT6 / 12SQ7 / 6SQ7.  The -AT6 has a µ of 70 and the rest of the tubes have a µ of 100 and the -AV6 triode is identical to the triode in a 12AX7.  The other part of the tube is a pair of diodes which have a common cathode with the triode but plates that can be used as shunt diodes for a distortion or rectifiers for an envelope-based function.
These are (as you say) all high-Mu and fussy to get working at 12V of B+.
I got curious. Duo-Diode/Triodes with low Mu.
12AE6 - 15
12BF6 - 16
12BU6 - 16
12DV7 - 14
12EL6 - 55 (but intended for 12V battery)
12FK6 - 7 (for 12V use)
12FM6 - 7 (for 12V use)
12FT6 -14 (for 12V use)
12SR7 - 16
12SW7 -16 (octal) (6R7)
Some of these are rare. The others will be like $5.
12EL6 is interesting. One alone will not distort much on guitar, but a gain of 10 (or another 12EL6) in front, it will slam.
You are correct about these low-voltage tubes being rare.  They were used in car radios in the late 1950's to early 1960's and rarely show up even at surplus stores.  If you check out sophtamps:
http://www.sophtamps.ca/www.sophtamps.ca/mambo/index862b.html?option=com_content&task=view&id=25&Itemid=37
They also use the 12U7 which is not in Paul's list (µ=20) and the 12K5 as a power amp.  This is a site dedicated to low-voltage amps and they even have a Ruby Tuby using a 12AX7 operating at 12 volts, so it is not impossible.
printer2
Fred
