REBOTE 2.5 mods
Started by global, September 18, 2018, 09:55:29 AM
global
Hello i m building this Rebote 2.5 now (yet 100% Tonepad layout)  , i m just waiting for the PT2399 to come soon to finish it .  Few time ago i read somewhere that someone did mod his Time knob by adding a 3 position switch to get some preselected time for the delay . i d like to make the same to get preset position of 75 , 150 and 300 ms ... does anybody get an idea of how to make it possible ???         i would like also to add 2 knobs for low pass and high pass filter (12db) ( maybe resonating with peak knobs but not necesseraly ) i will use this delay with the mixer's aux send and back into a channel of the same mixer so i dont need to get the filter into the PT2399 feedback loop itself (but it could be fun though) .    FOr the filters i hesitate between  fixed 12db frequency sweepable   or some fixed frequency  passive shelves with just "volume" knob .  At last i d like to put some modulation   . If someone has some ideas , schematics , layout , any suggestions welcome  , alsoi apologize for my poor english and also if those
BetterOffShred
Rebote 3 has modulation.  As for preset delay times, that seems incredibly boring instead of an actual analog rate pot..  but you could just set the pot where it sounds good , remove it and measure it, then add those values to a 3 throw rotary.  So when you turn the knob you're going from preset 1 to 3 ...
for delay with nice modulation try the dreamtime.
uses 2 x pt2399's for longer , cleaner delay... 8)
build your rebote as standard for now. its a nice simple delay, always useful.
just my 2p...
https://www.youtube.com/watch?v=3V4kzKXovT8&t=638s
BetterOffShred
concur.   The 2.5 never leaves my pedal table.   Ever.
Rob is right too, the Dreamtime is probably exactly what you're after.   I just need some 100n's and mine will be complete,  Robs Modulation sounds great too.
blackieNYC
I have a rebote 2.5 to which I added a second stomp switch, which selects between two Delay time pots. Typically one long and one short.
Quote from: blackieNYC on September 19, 2018, 12:43:01 PM
I've thought about doing exactly that, every time I build one I forget though :P
blackieNYC
... and I could easily see having the delay times fixed and preset, with internal trimmers or resistors. Just to cut down the knob count. A quick doubling, and Guitar Hero 300ms. Maybe even zero feedback (fixed).  For live use, one could easily get by this way IMHO.
