A newbe question
Started by whomeno, October 11, 2018, 09:39:41 AM
whomeno
which end is pin 1 on a cd4013be, 1 end has a u cut out and the other end has a dot?
Gear as of now
Gibson 2017 Les Paul Tribute T
Epiphone Les paul Special (upgraded)
Marshall DSL 20 Head
Peavy Valve king 20 W
2 X 12 Cabinet with celestion vintage 30 & celestion G12T-75
And a lot of pedals
Marcos - Munky
Cut or dot is the side with the 1st and last pins of an IC.  1st pin is the one on the left and the last pin is the one on the right, looking to the IC with the cut or dot pointing up.
whomeno
yes but which end is pin 1 on the cut side or the dot side it has both on chip
Gear as of now
And a lot of pedals
marcelomd
#3
Cut side is pin 1. If there is a cut AND a dot, the dot probably is the injection mould mark.
Or you could post a picture =)
EDIT: My intuition is that only the cut is deliberate. See picture. Lots of dots, but only one cut.
EDIT 2: This is just an observation, not a rule, but if you put the text in the right orientation, pin 1 is on the lower left.
whomeno
Gear as of now
And a lot of pedals
whomeno
Gear as of now
And a lot of pedals
Any orientation dot is on the corner.
I do not see one in that stock photo. The U-notch is clear.
Oversize stock image: https://www.mouser.com/images/texasinstruments/hd/ITP_TI_PDIP-14_N_t.jpg
Circles in the middle vent air out of the mold and are not for orientation. (Usually there are two, or none, or one on the bottom-- I guess this molder is OK with one, or the U-notch is also a vent; sometimes it is a mystery.)
Good overview: https://www.evilmadscientist.com/2010/basics-finding-pin-1/
marcelomd
QuoteAnd now here is a chip that has less of a "direct" indication of its orientations– no dot or half-moon shape. As we discussed earlier, you can rely on the orientation of the text in cases like this, and imagine an effective polarity mark on the left hand side of the chip. Pin 1 is on the lower left hand side.
Hah! I KNEW it!
