New info:
Early 70's Colorsound units:
T26 material, ui = 2200
P14x8 pot core, gapless with hole
AL = 2100 nH/t^2
Wire 38 AWG, bobbin fairly full so be reasonably neat.
L = 500mH +/- 20mH
RDC = 27.5 ohm to 28.0 ohm
About 488 turns.
Modern material is N48.
Lower loss than T26 so try adding 100k in parallel with inductor.
For some reason there's not a lot of *precise* info on the Colorsound.
Pot Core
Core P 14 x 8 (gapless with hole) ; 14mm x 8mm
Material: Siemens N22 (ui=2300)
Inductance 500mH ; nominal not measured
Wire 40 AWG ; guessed/assumed? not confirmed from DCR
Note:
I have seen:
T26 material (Siemens ,ui =2200, used for transformers)
Technically this would require 4.5% more turns.
Siemens Data
Matl Pot Core Spec
N22 ui = 2300
N48 ui = 2300 ue=1340 AL = 2100 nH
T16 ui = 2200
Turns Calculation
For 500mH:
- Calculation based on AL, N = 488 turns
(bobbin is only 43% full, AL might be 0.5% lower)
- Someone said they used 460
P14 x 8 Bobbin:
d = 7.1 +/- 0.2 mm
D = 11.5 +/- 0.2 (max)
b = 4.4mm
Resistance Estimate:
40AWG (dw=0.0787mm) *** assumed not confirmed by any measurement ***
(Ka=0.57 = wire area / bobbin cross-section)
460 turns , 40.93 ohms, Do = 8.88mm, lw ~ 11549mm
488 turns, 43.72 ohms, Do = 8.99mm, lw ~ 12336mm
Bobbin is not full of copper.
[Actual wire was 38AWG]
These resistance results imply the inductor is close to:
(IIRC most of these are on a P14 x 8 core.)
- 1968/9 Vox (Italy) "stack of dimes"
- 1970's Thomas (U.S.) "stack of dimes"
- 1970's Fasel
Whipple 30ohms
TDK 5103 japan marking 40ohms
TDK 5103 no japan marking 19 ohms
