HELP WITH A CHUNK SYSTEMS AGENT 00 MARK II
Started by DOND, November 04, 2018, 01:02:26 PM
DOND
Eb7+9
#61
Quote from: DOND on December 09, 2018, 04:10:55 PM
......this pedal is possessed
no, just poorly designed ...
if you get it to work somewhat cleanly it's only because you got lucky with OTA#2 having low input offset
and the BS ckt on the lower RHS (shorting the 324 to ground) will likely cause your IC to cook
again, luck ... depending on matching of rail split resistors ??!
DOND
Eb7+9.....I will agree with the design...now that I know how it works and know the chain...it's like shit through a fan (all over the place).the parts themselves weren't all that great,etc but fwiw,i think it was a great pedal to learn on as it had multiple problems....
DOND
well....after getting this pedal up and running and playing with it,i have to say this is the most annoying pedal I have ever heard..should have left it broken....junk
