Yep, I sincerely doubt anybody can hear the difference between 4.7pF and 5pF.
Whistles sound like an oscillation to me, are you using a known layout? Double check your wiring, move it around to see if it changes.
edit: just looked at a vero layout for it, that should be a 4.7nF not pF, the only pF caps are the two 10pF
edit 2: looked at a schematic that had a 4.7pF, maybe you should link to the schematic/layout you're using
