Anyone? Please help!!
Started by Willthebold, October 16, 2003, 04:13:27 PM
Willthebold
Hey guys, when I recently built my Scrambler I added in a volume control at the end of the circuit. I used a 100K pot to ground. Is there any way I could get the volume level any higher? Would using a higher value pot increase output. What is the best way to add a volume control to a project like this?
Will
Arn C.
One outer leg of pot to ground, one outer leg to circuit output and center leg out to jack
Is there any way I could get the volume level any higher? Would using a higher value pot increase output.   Try a larger value and see...
Arn C.
But I would try a 500k there.
 Then you could add even more resistance to ground, from the pot by adding a resistor there, to let even more signal through.
 If I'm wrong here somebody blast me...
jrc4558
go http://www.geocities.com/tpe123/folkurban/fuzz/snippets.html
This noble inventor has a plenty of very simple boosters.
Stick one in after the Scrambler.
