hi guys...just dug out my arduino UNO. as i have a tremolo on breadboard
and thought it would be fun to try a tap for it......simple led to ldr setup...
after seeing this guys video on tap tempo. which looks cool
https://www.youtube.com/watch?v=ur_PEUH7snshowever he is using an arduino NG.
and i cant get the code to load on my UNO. (forgive my noobyness) but can his NG code go onto my UNO?
here is his code : it compiles ok, but wont actually load. thanks in advance..
Tap Tempo
An experiment to detect tempo by tapping a button
Press a button connected to digital pin 12.
LED on pins 2-12 displays the beat pulse
LED on pin 13 shows the current button state (dim when button is pressed)
Digital Output <--------/\/ 220 ohm /\/----[LED]----> GND
(Digital 13 is wired up to the LED on the NG board. If you have an older
board, drop the standard LED between pin 13 and GND)
+------> +5 power
Digital 12 <-----+----[ switch ]-----/\/ 10k ohm /\/-----> GND
void setup()
pinMode( 12, INPUT ); /* tap button - press it to set the tempo */
pinMode( 13, OUTPUT ); /* button state display - not necessary */
for( int i=2 ; i<12 ; i++ ) {
pinMode( i, OUTPUT ); /* tempo display light - shows the current tempo */
int lastTapState = LOW; /* the last tap button state */
unsigned long currentTimer[2] = { 500, 500 }; /* array of most recent tap counts */
unsigned long timeoutTime = 0; /* this is when the timer will trigger next */
unsigned long indicatorTimeout; /* for our fancy "blink" tempo indicator */
void loop()
/* read the button on pin 12, and only pay attention to the
HIGH-LOW transition so that we only register when the
button is first pressed down */
int tapState = digitalRead( 12 );
if( tapState == LOW && tapState != lastTapState )
tap(); /* we got a HIGH-LOW transition, call our tap() function */
lastTapState = tapState; /* keep track of the state */
/* check for timer timeout */
if( millis() >= timeoutTime )
/* timeout happened. clock tick! */
indicatorTimeout = millis() + 30; /* this sets the time when LED 13 goes off */
/* and reschedule the timer to keep the pace */
rescheduleTimer();
/* display the button state on LED 2 */
digitalWrite( 13, tapState );
/* display the tap blink on LED 13 */
if( millis() < indicatorTimeout ) {
digitalWrite( i, HIGH );
} else {
digitalWrite( i, LOW );
unsigned long lastTap = 0; /* when the last tap happened */
void tap()
/* we keep two of these around to average together later */
currentTimer[1] = currentTimer[0];
currentTimer[0] = millis() - lastTap;
lastTap = millis();
timeoutTime = 0; /* force the trigger to happen immediately - sync and blink! */
void rescheduleTimer()
/* set the timer to go off again when the time reaches the
timeout. The timeout is all of the "currentTimer" values averaged
together, then added onto the current time. When that time has been
reached, the next tick will happen...
timeoutTime = millis() + ((currentTimer[0] + currentTimer[1])/2);
