An updated version with some corrections and one new feature.
now you can configure MAXTAP in this line:
#define MAXTAP 8000
It defines a timeout between taps. Any tap interval higher than this value will be ignored. This avoid that after some minutes, if you push the tap once, everything is screwed.
Tap Tempo using Jleds
#include <jled.h>
#define THRESHOLD 20
#define EXP1 A0
#define MAXDELAY 3000
#define MINDELAY 1
#define MAXTAP 8000
int period = 2000;
JLed leds[] = {
JLed(3).Breathe(period).Forever(),
JLed(4).Blink(period/4*3, period/4).Forever(),
JLed(5).FadeOff(period).Forever(),
JLed(6).FadeOn(period).Forever(),
JLed(LED_BUILTIN).Blink(period/2, period/2).Forever()};
int lastVal = 0;
int tempAnalog = 0;
boolean PotControls = true;
void setup()
pinMode( 12, INPUT ); /* tap button - press it to set the tempo */
int lastTapState = LOW; /* the last tap button state */
unsigned long currentTimer[2] = { 500, 500 }; /* array of most recent tap counts */
void loop()
/* read the button on pin 12, and only pay attention to the
HIGH-LOW transition so that we only register when the
button is first pressed down */
int tapState = digitalRead( 12 );
if( tapState == LOW && tapState != lastTapState )
tap(); /* we got a HIGH-LOW transition, call our tap() function */
lastTapState = tapState; /* keep track of the state */
// update leds
for (auto& led : leds) {led.Update();}
// check pot value
poll_pot();
delay(1);
unsigned long lastTap = 0; /* when the last tap happened */
void tap()
if ((millis()-lastTap)>MAXTAP){
lastTap = millis();
return;
/* we keep two of these around to average together later */
currentTimer[1] = currentTimer[0];
currentTimer[0] = millis() - lastTap;
lastTap = millis();
// establish new period
period = ((currentTimer[0] + currentTimer[1])/2);
PotControls = false;
// update leds period
update_leds();
void update_leds(){
leds[0] = JLed(3).Breathe(period).Forever();
leds[1] = JLed(4).Blink(period/4*3, period/4).Forever();
leds[2] = JLed(5).FadeOff(period).Forever();
leds[3] = JLed(6).FadeOn(period).Forever();
leds[4] = JLed(LED_BUILTIN).Blink(period/2, period/2).Forever();
void poll_pot() {
// Read analog value
tempAnalog = analogRead(EXP1);
// Convert 10 bit to milliseconds, 3 seconds maximum
tempAnalog = map(tempAnalog, 0, 1023, 0, MAXDELAY);
tempAnalog = constrain(tempAnalog, MINDELAY, MAXDELAY);
// Check pot value and compare variation with threshold
if((abs(tempAnalog-lastVal)>THRESHOLD))
// update period with pot value
period = tempAnalog;
//return control to Pot
PotControls = true;
// Store current value to be used laters
lastVal = tempAnalog;
// update leds with new timing
update_leds();
//delay(5);
