Help. Tonepad CE2 debugging
Started by syamilaliff, December 15, 2018, 03:27:39 AM
syamilaliff
Hi,
I got a problem with my build.
It seems that the MN3007 and MN3101 is not getting the correct voltages.
I run countless of times checking for bridges but cant seem to find one.
Here are the voltages :-
MN3101
1. 9.2
2. 9
3. 0.02
4. 9.1
5. 9.2
6. 9.2
7. 0.68
8. 9.2
MN3007
1. 9.2
2. 9.2
3. 5.3
4. 9.2
5. 0
6. 9.1
7. 9.2
8. 9.2
IC1
1. 4.5
2. 4.5
3. 4.5
4. 0
5. 4.5
6. 4.5
7. 4.5
8. 9.2
IC2
1. Varies
2. 4.58
3. Varies
4. 0
5. 4.58
6. 4.57
7. Varies
8. 9.2
Seems that my signal is lost at C10. I got sound at R13. I've spent one whole day troubleshooting this circuit and still cant find any bridge.
Any help is appreciated on where I should look further.
Thank you.
Slowpoke101
The voltages on IC1 and IC2 look good but IC3 and IC4 are very wrong.
The clocking chip (IC4) is not working. The following voltages are from a working CE-2 clone with both Depth and Rate controls set to mid-range;
IC3 - MN3007
1= 9.1V
2= 4.7V
3= 5.1V
4= 0.65V
5= 0V
6= 4.66V
7= 5.08V
8= 5.08V
IC4 - MN3101
1= 9.1V
2= 4.66V
3= 0V
4= 4.7V
5= 0.4V (varies slightly)
6= 7.9V (varies slightly)
7= 1.7V to 3.2V (varies relative to Rate and Depth)
8= 0.616V
There have been quite a few fake MN3007 chips sold and they do not work at all. Remove IC3 and re-measure the voltages on IC4 and see if they are now close to the voltages above.
Be prepared to source another MN3007 and probably a MN3101.
syamilaliff
Quote from: Slowpoke101 on December 15, 2018, 05:35:43 PM
IC3 - MN3007
1= 9.1V
2= 4.7V
3= 5.1V
4= 0.65V
5= 0V
6= 4.66V
7= 5.08V
8= 5.08V
IC4 - MN3101
1= 9.1V
2= 4.66V
3= 0V
4= 4.7V
8= 0.616V
It was the BBD. Tried a few of them and only a pair of them works.
Thanks for your help.
