Tonebender MkI More Bass
Started by Mcentee2, December 21, 2018, 04:26:42 AM
Mcentee2
Have a Tonebender MkI that currently has standard cap values in, from input to output:
0.01uF input
25uF between Q1 and Q2
0.1uF between Q2 and Q3
0.1uF Output
Although it probably is a "true" TB MkI sound, it is a little thin for me - what is the easiest way to get more bass from it ?
Do I need to tweak all the caps larger, or will just one of them do the trick ?
antonis
Hard to say without schematic..
Supposing series configuration for all caps, you have to deal with respective resistors (impedances) to find out their individual HPF cut-off frequencies, lower the higher of them and check for possible "overlap" with the closer unaltered..
Mcentee2
Quote from: antonis on December 21, 2018, 06:34:05 AM
This is the "standard" TB Mk I here that I have  seen on a few posts so far in DIYSB  threads:
http://www.luciferstrip.com/fuzz/tone%20bender%20mk1.jpg
Just tried some caps out - anything more than the 0.1uF does add more bass progressively.
1uF seems a sweet spot, at 10uF however starting to hear creeping in a "capacitor charging delay" after heavy chords. The cap seems to be "used up" then take up to half a second or so to recharge and start passing signal again - quiet then normal hiss creeps back in.
