Where's Help with learning Capacitor Markings?
Started by Guitarist1983, December 21, 2018, 05:06:40 PM
Guitarist1983
Cap markings are a tad confusing.
For example, I've got a blue 7mm square cap (3 mm thick, 5 mm between leads) marked u1j100 A1j5. I've searched the interweb for the answer and came up empty.   Digikey - nope,  Mouser - nope.
It's obvious to me that I don't know how to look up caps.   Any pointers?
thermionix
That's a weird one.  My best guess is 100pF, but I don't recall seeing a box cap with a value that small.
Guitarist1983
I'm about to guess u1j100 is 0.1 uF,  j= 5% tolerance, and 100 Volt   the A1j5 is some manufacturing stamp?
I bought one of these to help me read oddly marked caps:
:icon_wink:
I've got a different spin on this to thermionix.
Normally letters like K (10%) and J (5%) are for the tolerance.   Quite often you will see the marking as 100K 2n2K (or 222K).  Then you might get 2n2K100 (or 222K100)for 2.2n 10% and 100V.  The thing I'm working off here is the ordering.
So u1J100  I'm *guessing*  0u1 = 100nF  J 5% and 100V.
As for the A1J5  I don't know.  I can only assume it's the manufactures code for the model details.
EDIT: Guitarist1983  just posted the same thing as me!
thermionix
Quote from: Guitarist1983 on December 21, 2018, 05:46:44 PM
Yeah that's probably more likely.  Would've been nice of them to put "0u1" at the start.  But Eric has the ultimate solution.
thermionix
Quote from: Rob Strand on December 21, 2018, 05:50:29 PM
And I was simul-posting with you.  (Got distracted for a few minutes)
FYI, See reply #4
http://www.madbeanpedals.com/forum/index.php?topic=1733.0
Quote(Got distracted for a few minutes)
Everyone has to scratch at some point  ;D
I'm another one who uses a bridge, in my case an AideTek DM4070, to ensure anything I put in circuit is what I think it is.  I had an 20µF 450 volt cap that measured 0.2µF on the bridge after long storage.  I am certainly happy to see that components have not deteriorated over time and even happier to see ones that should be culled.
Guitarist1983
Quote from: amptramp on December 21, 2018, 07:20:15 PM
Perhaps Santa will order me an AideTek DM4070 or some other LCR meter from Amazon. I assume using an LCR is "the" way to check the caps in my old amps.
Quote from: Guitarist1983 on December 21, 2018, 05:06:40 PM
Cap markings are a tad not in the slightest bit confusing.
For example, I've got a blue 7mm square cap (3 mm thick, 5 mm between leads) marked u1j100 A1j5. I've searched the interweb for the answer and came up empty. ....
me too, only mine are 7,5mm spacing, and marked [Siemens logo] µ1K100. which I know is 100nF, 10%, 100V. I also have a green ERO marked "1," on the roof, and on one face "K 63 1826 X7", which I know is a 1uF 10% 63V from their 1826 range of MKT's. also a yellow marked "D105J [some 8-bit logo]" which I can say is 1uF 5%, but I can't quote a voltage.
