May Overdrive - 2 curious problems
Started by rockaffe, January 06, 2019, 01:08:21 AM
rockaffe
Good morning (yep, in Italy is 7am now :D ), I have two curious problems with the May Overdrive of which I spoke here:
https://www.diystompboxes.com/smfforum/index.php?topic=121615.0
Here are the problems:
- The pedal works and sound fine but, when I turn the guitar volume to 0, a really loud whistle starts.
- I added a volume control (100K Log) connecting the circuit output to lug 3 and using lug 2 as my new output, but the control does't work. I can hear "something" turning down but definitely not the pedal volume :D
Any ideas on how to solve these two problems?
BTW this is the project page: https://paulinthelab.blogspot.com/2017/09/may-queen-overdrive-originally-by.html
Thank you!
nickbungus
Have you got pin 1 going to ground on the volume pot?   If not,  try that
To the extreme, I rock a mic like a vandal.
Light up a stage and wax a chump like a candle.
rockaffe
Thanks, this solved the volume problem, now it works correctly.
Still got the whistle problem. I've tried two different guitars, and the problem is there with both...
Isn't the 10K trim-pot the volume control? It does essentially the same thing as a potentiometer across the output.
I don't see why it should whistle. Since it happens at ZERO guitar impedance, I would try about 5K in series with the input cap.
pinkjimiphoton
bad guitar cord to the input of the effect
bad ground somewhere
cold solder
Slava Ukraini!
~Jack Darr
