Power suply. Works great without the LED. With is regulator get's HOT
Started by DeusM, January 11, 2019, 07:20:43 PM
DeusM
Hi guys. So I built this power supply. The problem is that when I put the LED it doesn't work at all. And the regulator get's hot pretty quick. I have no idea what could it be. I double triple checked the LED polarity. I used a 4,7k resistor in R4. I read something that changing the value of R3 I can modify the LED intensity. Can it be R3? I read that it and R1 shouldn't go up to 5K.
It's not the amps that kills you. It's the "mojo"
Have you adjusted the trimmer yet to get a high-ish output voltage? I'm suspecting not: what you describe sounds like it's currently set to give a very low voltage output.  This means, 1) it's dropping a lot of volts (so the regulator gets hot), and 2) there's not enough Vf to light the LED.
italianguy63
To me sounds very "short-ish" since it won't light.  Maybe check the LED polarity again.
Have you tried putting the LED "upstream" of the regulator?
MC
measure the voltage at the regulator "In" pin, then remove D3, and remeasure the input and output voltages. please.
DeusM
Quote from: duck_arse on January 12, 2019, 08:42:46 AM
Why? The please? Should I be scared?  :icon_frown:
To measure it I have to put one probe on the uput or input pin and the other on the negative of the circuit?
GGBB
Yeah - a 2.2V zener there does not seem at all right.
DeusM
Quote from: GGBB on January 12, 2019, 02:59:22 PM
My bad. It's actually a IN4748. I just puted what I found on Multiboiard
DeusM
This schematic doesnt have that diode. It's just for polarity protection. i don't think it shloud be a problem.
DeusM
Ok. So only the first jack works. And the LED turns on only when there is a conection ther. Could it be that I conected the black pins togheter in the board?
DeusM
Okay. I cut the left lug and all works great. LED turns on, but only when there is a pedal conected. Is that how its supouse to work?
