Is it okay to have a small resistance between 9v and ground?
Started by Esppse, January 13, 2019, 12:11:21 AM
Esppse
Hello,
I'm building a project where 15 distortions and modulation fx are daisy chained.
I have not powered up yet. Just doing continuity tests. There is zero continuity between audio in/out and ground. Good.
There is 577 ohms between 9v and ground when every thing is unpowered. Is that ok? Is this how transistors/ICs/components are supposed to display resistance when no voltage is applied? I was very careful and tested each circuit individually for sound and functionality before daisy chaining. All grounds are star grounded. Just concerned a bit before powerup.
anotherjim
If all of that looked like it was only going to draw 15mA (9/600) I would be pleased. However, the test meter is not going to drive the circuits into their fully biased working condition. It is a good indication that there is unlikely to be anything nasty going on and reduced likelihood of hearing that "Pffft" sound and wisp of smoke when you power it up.
But you always need to be ready to turn it off quickly ;)
Esppse
OK thanks a lot, I'll be sure to take quick precautions!
Don't get me wrong but if you measure with your tester set on "continuity" with reversed probes, you might get 577mV(not Ohms) reading in case of reverse polarity protection diode between +9 & GND ..  :icon_wink:
Esppse
Ooomph, it was on continuity. Yikes. OK I switched it to 2000 ohms setting, it says 1277 ohms, does that raise alarms or is that still cool?
Can't say for sure without any schematic but 7mA current draw (without semiconductors activated) should be considered cool enough..
A rough estimation of expected resistance could be made by any obvious resistors set between +9V & GND..
(e.g. Vref voltage dividers, transistors bias networks, etc..)
Esppse
Yeah most are distortions that draw about 5 to 15 ma. All together every effect should sum up to about 300ma maybe since there are a couple digital fx too.
