Tascam 464 separate outputs modification question
Started by FUZZZZzzzz, January 13, 2019, 11:54:47 AM
FUZZZZzzzz
So, I hope I'm not breaking any rules here with something slightly less stompbox minded. I'm currently restoring a tascam 464 4 track cassette recorder. It's the smaller brother of the 488 and 488mkII, which I also owned before. I saw an ad on eBay where someone is selling mods for 4 separate outputs (post eq) that you can send to your DAW so that they all stay in sync. I have not found any service manual or schematic for the 464, but have for the 488. Is adding a separate output as simple as taking the signal for example from C112 for channel 1? Just after the EQ?
service manual:
http://slugbug.sound-club.org/information/Tascam%20488%20Mk1%20Service%20Manual%20%28PNG%29/
Quote from: FUZZZZzzzz on January 13, 2019, 11:54:47 AM
Yes, it looks like it. But note that the channel fader doesn't affect the separate output.
HTH,
Tom
FUZZZZzzzz
thanks! so a better spot would be lug 2 of the r120 input fader?
anotherjim
If you want you can take output from the fader wiper (post-fader). Or the fader top (pre-fader) C112. Or before the EQ (pre-eq) C108. Or indeed, fit switching to select with.
wavley
I would look at the Tascam 244 and see where they did it, concept should be the same.
But I think everybody has already nailed it.
Bone is in the fingers.
EccoHollow Art & Sound
eccohollow.bandcamp.com
QuoteI would look at the Tascam 244 and see where they did it, concept should be the same.
The 244 OM hints at post fader pre pan.
FUZZZZzzzz
