Author Topic: Aion Electronics L5 Preamp  (Read 4298 times)
chongmagic
« on: February 01, 2019, 12:53:05 AM »
I am having an issue where the bypass works on its on but the channel 1 and 2 LEDS do not illuminate unless I connect the channel pads on the 3PDT switch PCBS. Otherwise channel 1 and channel 2 seem to work, just no LEDS illuminate. I can hear both channels by pushing the footswitch. But it is not indicated by the LEDS.
GGBB
Re: Aion Electronics L5 Preamp
« Reply #1 on: February 01, 2019, 08:24:21 PM »
Most of us probably either have no idea what this pedal is, or do not have the circuit memorized. Please follow https://www.diystompboxes.com/smfforum/index.php?topic=29816.0. Aion is active here under the user name "aion" if you want to contact them directly.
« Reply #2 on: February 02, 2019, 05:10:05 AM »
You might also want to ask a moderator to move this thread into the main "Building ..." part of the forum, where there's lots more passing traffic.  It's the same place as the "Debugging" thread that Gord has linked to.
