Midi CC to PC switching interface
Started by Steviebabes, February 11, 2019, 03:56:58 PM
pruttelherrie
Have you tested reception and sending individually?
Sprinkle some println()'s throughout the code to monitor incoming and outgoing values, to make sure that part is ok.
[edit] oh wait, it's a Nano with only one serial port which is already used for the MIDI port, that won't work. Can you add LEDs to blink upon reception/forwarding?
Willypp
IT WORKS!!!! IT WORKS!!!
I'd soldered midi in 4 to midi in 5 on the plugs and vice versa for the midi out plug, and now it's working exactly as I wanted.
potul
I was about to writ this: "90% of the time my MIDI devices don't work, I misconnected pins 4 and 5"
But I see you already figured it out. It's not always trivial to see which is which in the diagrams you find on the web.
I'm glad to see it's working. Welcome to the MIDI madness.
Quote from: potul on August 18, 2020, 04:57:04 PM
+1 This! It's amazing how many different ways there are of interpreting "back" and "front" in a simple diagram of a MIDI socket or plug!!
pruttelherrie
Quote from: ElectricDruid on August 19, 2020, 01:53:24 PM
+1. Happens to me all the time...
Some of the sockets/plugs have the numbering embossed in the plastic, but not all of them.
