Author Topic: Using battery + DC power supply?  (Read 1155 times)
soma89
« on: April 05, 2019, 09:11:48 AM »
I am working on a simple boost build and, want to put in a DC 9v adapter jack, along with a 9v battery option (like in most modern pedals).
i) If the 9v battery input & adaptor jack are connected to the same "9v bar" on the board, would this cause any complications if an adapter is connected AS WELL AS a battery?
ii) Is it as simple as connecting both power sources to the same 9v bar?
What I mean by "9v bar" is the area in the circuit requiring the 9v power btw.
Thanks in advance
antonis
Re: Using battery + DC power supply?
« Reply #1 on: April 05, 2019, 09:24:30 AM »
No problem other than charging a non-rechargeable battery.. !!  :icon_wink:
If you use appropriate DC adapter (the one with 3 lugs which "isolates" the 2 positive connections..)
See below for DC connection configuration..
« Last Edit: April 05, 2019, 09:37:30 AM by antonis »
bamslam69
« Reply #2 on: April 07, 2019, 07:01:06 PM »
There's circuits available on the net that show how you connect it.
A stereo input jack, and a switched dc jack are the key.
Have a look at www.Diyguitarpedals.com.au . Pretty sure I learnt the wiring there.
Rhythym in jump, dancing close to you
