Cap polarity question
Started by Antonio1963, April 24, 2019, 04:34:11 PM
Antonio1963
The 220nf cap above IC socket 1 looks like a ceramic cap. I have an electrolytic in .22uf which I believe is the same value. The problem is that this capacitor is polarized and I'm not sure which direction the negative should go or if I could use the polarized capacitor in the spot ?
Kevin Mitchell
Short and sweet answer - it doesn't matter.
-KM
This hobby will be the deaf of me
Antonio1963
Great, I thought it would since it was polarized. Thanks for the help Kevin.
Although I totally agree with Kevin, I'd sleep in politically correct peace with its positive leg at right side..  :icon_wink:
merlinb
Quote from: Antonio1963 on April 24, 2019, 04:34:11 PM
Are you sure it says .22uF and not 22uF? I've never seen such a tiny electrolytic cap...
are we just waving our hands over the cap and saying doesn't matter? looks like a ceramic doesn't cut the mustard if it goes in backwards and the circuit won't go. show us the circuit diagram and we might be able to say.
Antonio1963
Quote from: merlinb on April 25, 2019, 10:54:44 AM
It's a 220nf ceramic cap.  I thought that I could substitute a .22uf electrolytic capacitor. Since I don't have a 220nf ceramic cap.
merlinb
Quote from: Antonio1963 on April 25, 2019, 03:51:44 PM
I don't think they even manufacture .22 electrolytic caps... perhaps you have misread the label? Anyway it doesn't need to be 220nF; anything from 220nF up to 1uF will do.
Positive should be on the right hand side, since it goes to the same place as the 1uF cap nearby.
Schematic:
https://elektrotanya.com/mad_professor_snowwhite_autowah_guitar_effects_schematic.pdf/download.html
IvIark's layouts don't (generally) distinguish between different kinds of non-electrolytic caps.  You just get an anonymous brown blob.  Brown doesn't mean ceramic.  Any film cap would do nicely.
Slowpoke101
#9
Merlin is correct with his advice on the polarity required. I even took a few voltage measurements from my board and that polarity is correct for an electrolytic capacitor in that position. The value is not really critical at all.
Why do you have 0.22uF electrolytics ? I thought I was the only person mad enough to actually have any (about 30 ) but my excuse is that they were used in some Motorola commercial 2-Way radios - needed to repair RSSI circuits at times.
Quote from: Slowpoke101 on April 26, 2019, 03:59:22 AM
still in my drawer - 4 x 0u22 100V & 2 x 0u47 63V, from a failed teevee repair, turn of the century.
Antonio1963
This is the box with the caps.
anotherjim
Electro cap values go down to at least 0.1uF. I suppose they were a viable choice for small size and voltage rating before film caps got good & cheap.
If it's the cap feeding the envelope sensitivity amp, it don't really have much voltage difference across it but might as well be the same way around as the cap going into the filter (C11). Mind you, for guitar, I don't think you'll hear much difference if the sub was a 100nF.
Mouser lists 30 in-stock products 0.1u and 0.22u, Aluminium Electrolytic Axial/Radial (with legs). 50V-200V. Generally thousands in stock. 10 cents to 40 cents; most under 25 cents. 0.22u 200V Nichicon High Temp just $0.25 (10c quan 100), 3k in stock.
nocentelli
#14
I still have most of a bag of 0.1u electro's I bought in error a number years ago. Never any use, since 100n is so common I have dozens of poly box and ceramics in that value
