Author Topic: Simple Digital Delay  (Read 9091 times)
Leetut
Re: Simple Digital Delay
« Reply #40 on: July 18, 2019, 06:38:03 AM »
Ice-9, you're in Newcastle!!  I live in Birtley
I'm struggling to find a supplier of the FV-1 chips.  Cant find them from the recommended distributors.
I’m in Sunderland!
nickbungus
« Reply #41 on: July 18, 2019, 07:12:41 AM »
The North East Solder Sniffers!!
To the extreme, I rock a mic like a vandal.
Light up a stage and wax a chump like a candle.
nickbungus
« Reply #42 on: July 18, 2019, 07:57:54 AM »
Going to repost this so its not lost on the bottom of the page :icon_lol:
I'm just finishing off the schematic and then I'm going to tidy it up.  I've got 2 isolated outputs for the 3 amp setup that route the signal back to the main output if a Jack isnt present to avoid ground hum.  Not sure if I need to add opamps to mix the signal back into the main output if there isnt a connection?
Also, I think I'll add 3 external level pots.  Should help get the mixing if required.  (Also I've put the opamp as a LM324 but thats to be decided - I just put a quad on just in case I needed some to mix signals).
Also I've made a mistake with the switched Jacks and connected the switched signal to ground - sorry/
« Last Edit: July 18, 2019, 08:06:52 AM by nickbungus »
Digital Larry
« Reply #43 on: July 18, 2019, 11:31:10 AM »
I think Frank (one of the FV-1 designers) talks about using an anti-aliasing low pass filter between 2 chips if daisy chaining them, or in the feedback loop if it is external to the chip.  Something about preventing aliasing of out of band signals due to delta-sigma or sigma-delta or pi beta theta epsilon or one of those other fraternities.  I've never daisy chained my FV-1s so I'm not sure about it, but it would be good to know that this is not a problem before committing to build such a complicated beast.
Might be worth inquiring over at the Spin forum.
Digital Larry
DSP tinkerer and former transistor twister
Ice-9
« Reply #44 on: July 19, 2019, 10:29:10 AM »
Larry, The schematic snippet I drew has the anti aliasing filtering in the schematic as per datasheet so should work fine.
www.stanleyfx.co.uk
nickbungus
« Reply #45 on: July 20, 2019, 07:58:26 AM »
Cheers guys.
Ice-9
« Reply #46 on: July 21, 2019, 06:45:14 AM »
I’m in Sunderland!
What' s the odds eh! three of us all just round the corner from each other.
www.stanleyfx.co.uk
