Analog button to send MIDI Program Change message?
Started by m10071978, July 17, 2019, 03:37:55 AM
m10071978
Hi to clever people)))
I have a distortion pedal without MIDI and FX unit with MIDI which can
change its preset number on receiving PC message.
Presently when I turn on distortion  I have to tap on FX pedal simultaneously (to turn delay/chorus off).
Are there any small solutions to tap only once? I.e. send a control message to activate preset #1 from pedal to MIDI IN?
I see it as a small extra footswitch button which I could add to my Dist pedal.
But what would be in between this button and MIDI input of my FX unit?
I have a soldering experience, but never dealt with MIDI constructions))
FiveseveN
Quote from: FiveseveN on July 17, 2019, 05:09:19 AM
Quote from: m10071978 on July 17, 2019, 03:37:55 AM
A microcontroller. See here: https://www.arduino.cc/en/tutorial/midi
Yes, and it really wouldn't need to be much more than just the bare microcontroller either. For sending MIDI, you only need a MIDI socket and a resistor - that's it. The UART on the microcontroller does the rest. MIDI *input* is opto-isolated and a bit more complicated, but for output, you don't need to worry about that.
pruttelherrie
Quote from: ElectricDruid on July 17, 2019, 02:21:58 PM
You won't even need an actual button if you read the state of the distortion off the LED.
All it would take is an Arduino Nano clone (<$3 on eBay), a resistor and a MIDI socket (as Electric Druid wrote). Current draw will not be optimal with a standard Arduino Nano, but it's *probably* the quickest solution.
potul
If  your FX unit has an Send/receive loop, it might be better to do it the other way around. You put the distortion in the loop, and control if grom the FX unit.
