Solder lug pot tips
Started by Billyhank, August 15, 2019, 09:26:52 PM
Billyhank
Hey, everyone!
  I'm building a plexi kit, (I've also got a KOT that uses solder lugs too.)and it came with solder lug pots.
Does anyone have any pointers on the best way to get them in correctly?
I'm concerned with height when I solder them onto the board. I don't want them to be too high or low. I can cover the bottoms of the pots so they don't short out.
I'm probably overthinking the issue.
Any tip would be greatly appreciated.
DIY Bass
Depends on how it all goes together.  The kits I have built with solder lug pots were designed so that you could loosely attach the pots to the case, wiggle it until the PCB would slip nicely over all the lugs, solder them in and then tighten the pot nuts.  Although that is a bit of work to get them in place, if you do have to remove the board you usually don't need to de-solder.  Just undo the nuts and it should all slide in and out.  The ones I had needed you to solder the input/output and power jacks to the PCB first.  They then located into their holes and held the board while the pots and switches were soldered in.  Good luck
Phoenix
Just to clarify something, as I'm struggling to understand your difficulty, this is a potentiometer with solder lugs, or do you mean some other type?
digi2t
Use solid core wire.
Doesn't matter if they are PCB pins or solder lug type. If PCB pin type, then just make a hook on the end of the wire, and solder it. If solder lug, then insert it into the hole and solder.
If your pots are "bare backs" (as imaged by Phoenix), then you can either place a piece of sticky foam on the back side, or, make a jig that will lift them off the board to a desired clearance and solder them in. Personally, I like to practice "safe pot", so I buy the ones equipped with condoms from Tayda.
I've been using only the Tayda pots with PCB pins for years now, and I make the pins with AWG20 solid core wire. It's the most cost effective solution I know. This method also allows you to compensate for situations where components with higher deck heights may be present.
Pro tip #1: When soldering the pot to the board, always start with the center lug, with just a tiny bit of solder. Just enough to hold it in place. You can then move the pot around a bit, to get it perfectly centered and parallel to the board. Then solder the two outer pins first, finishing with the center one.
Pro tip #2: Always solder in the pots last. If you have switches on the board, do those first, especially if Alpha type rotary switches are involved. The Alpha's have very high deck heights, so you'll need to jig your pots up even higher than usual. Not something you want to deal with after the fact. :icon_wink:
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
Billyhank
Quote from: Phoenix on August 16, 2019, 06:24:29 AM
Yes, that is the type. I'm more used to the pcb mount pots
Billyhank
Quote from: digi2t on August 16, 2019, 07:03:46 AM
Awesome!
Thank you for the tips!!!
I'm so glad I joined this community.
pro tip #3 - if using tinnned copper wire coming of a roll, stretch it first. wind the free end around something - a screw in your desktop - unwind 'a length' of wire, and then pull on the roll so the length stretches out all the kinks. then cut the length near the roll and cut the wound end from/at the screw.
pro[?] tip #4 - one straight wire, and two with slight kinks in them [use your pliers]. not so big a kink that the wires short w/ each other, but enough that you have some strain relief when they are all soldered, just in case.
Billyhank
I don't have solid wire. I was going to use the thick leads from some diodes that aren't useful to me. I bought a bunch in bulk and got a lot that aren't used for pedals. So, I was going to cut the leads and use those.
I do appreciate your help. I'll be getting some solid wore soon. LOL.
