Engineers Thumb distorting
Started by guidoilieff, August 31, 2019, 07:08:58 PM
guidoilieff
Hi. I've made this pedal using this layout https://www.dropbox.com/s/purgnc68qed3n7t/Engineer's%20Thumb%20build%20doc.pdf?dl=0
Voltages seem ok. Pin 1 of IC1 is at 8.5v, drops to 4.5 when I pick a string on my bass and slowly rises again to 8.5.
Here is the problem: Using a sound probe signal reaches pin 3 ok, but in pin 1 and 2 the sound comes distorted/ gated, kinda like a bad biased transistor if you know what I mean.
I tried swapping the IC and thats as far as my brain goes. Should I lower the value of R2 or just the opposite? Maybe the problem is on C2 and forward? Idk. Any suggestion is welcome.
Sorry I cant upload a pic, my phones dead.
guidoilieff
Doesn't the Ratio pot controls gain on IC1?
Maybe I should make it a 2 knob version. What are the best resistor values for bass?
merlinb
Quote from: guidoilieff on August 31, 2019, 10:29:22 PM
Yes. Turn the ratio control to minimum and you should have a unity gain buffer, totally clean. If you don't then you've make a build error somewhere.
FYI, one thing that schematic needs is a 220k resistor in series with the release pot, otherwise you'll get funky behaviour when the release is turned down to minimum.
Same as for guitar, but you can increase C3 to 2.2uF if you like.
guidoilieff
#3
Quote from: merlinb on September 02, 2019, 05:52:48 AM
Thanks for the reply, such an honor. Sorry for my English.
So its normal that 7/8ths of my ratio pot distorts with this design?
merlinb
Quote from: guidoilieff on September 02, 2019, 08:57:56 AM
Yes that might explain the problem.
guidoilieff
#5
Well.... I tested the pedal with an amp and the clipping leds started flashing and now the pin1 of IC1 doesn't rise to 8.5v anymore, it is stuck at 4.5.
Maybe in 10 years when my country is no longer in crisis I can get another 13700 because I think it might be broken now... IDK how to check that.
merlinb
Quote from: guidoilieff on September 02, 2019, 11:04:35 AM
Are you using an active bass, or something?
guidoilieff
#7
Quote from: merlinb on September 03, 2019, 04:39:48 AM
Nope. Just a passive bass and guitar.
The good thing is that I tested the 13700 in a Coron DS7 and it works.
What caught my attention is that in the 3 lugs of the Ratio and Release pots there is 4.4v (release is actually 4v/variable/4.4v)
And here is a voltage list because now voltages are weird I guess
T1
C 1
B 3.7
E 4.45
ic 1
4.42
4.42
4.30
0
4.40
4.40
4.40
9
ic2
0
0
4
0
0
4.4
3.7
9
ic3
1
0
4.4
4.4
4.4
0
0
0
0
0
9
0
0
0
0
0
Thanks again for your time. I know this can be a little bit abstract.
merlinb
Judging by your voltages it looks like you have a problem around IC2A, like maybe a short to ground?
befey
This schematic seems slightly different than the one posted on your website. Especially around the LM13700.
Sm4sh
Hello,
I don't know if I should start a new topic but this one matches my problem.
I've used a similar 5 knob version of the circuit and I'm experiencing a distortion/crackle when the ratio is pushed past noon. I'm under the impression that the crackle happens at the end of the release. Not sure...
I've tried to :
- Change the 1uF elec caps to ceramic (C3,C4)
- Swap the LM13700
- Increase the resistor in series with the Release pot from 100k to 220k (I'm using a B500K)
