Bought a pedal off the bay which was not working and thought i'd fix it up to resell. I'm not sure why but for some reason i really wasn't expecting it to be all SMD inside.
I had to sign a NDA to get a copy of the schematic so i probably shouldn't go into too much detail but i had a quick probe around inside earlier and noticed that there's 18v at the DC in (it's an 18v pedal) then on the other side of a 100R resistor it drops to 3.9v. That side of the resistor connects to a 220uf cap and a 1N4001 both going to ground. Then it's the input of a 15v regulator.
Question is, which is the most likely to have failed? My first thought was the 220u cap, but could also be the regulator no? There's 2.5v on the output of the regulator so it is dropping some voltage.
Or could it be that something has failed further down stream that is causing this massive voltage drop?
