Author Topic: Fender Jaguar - Alternative to changing the pots  (Read 2218 times)
iam_jrm
« on: September 15, 2019, 12:02:15 PM »
Hi
I have a Jaguar, which obviously can sound like an ice pick due to the 1 Meg pot.
Rather than change the pots in the guitar I would rather build a stomp box with an on/off switch, and a toggle between a 250k or 500k pot/resister.
I have no idea on where to start.
Could some one make me a schematic?
Many thanks
J0K3RX
Re: Fender Jaguar - Alternative to changing the pots
« Reply #1 on: September 15, 2019, 12:58:51 PM »
Why not just install a treble bleed cap/resistor on the volume pot?
« Reply #2 on: September 15, 2019, 06:21:09 PM »
You could have a buffer with a "suckage" control which is a variable resistor to ground at the input to the buffer.  It should be in series with a resistor so you can't have a situation where you can wipe out all the sound.  The resistance in series with the inductance of the guitar cuts the treble.
j_flanders
« Reply #3 on: September 15, 2019, 06:35:09 PM »
A (variable) resistor to ground, parallel to your volume pot?
As incredible as it may sound you already have exactly that: the tone control on your guitar...
Turning your tone control to 5 (on a linear pot) would sound exactly the same as changing your 1M Ohm volume pot to a 500k Ohm pot.
Turn it to 2,5 and it'll sound like a 250k vol pot, although at that point you'll start to hear the effect of the cap on the tone pot.
Which is why we have a cap on the tone pot?
The (additional) resistive load lowers the amplitude (Q) of the resonance peak (usually in the treble range).
This is what the tone control on a guitar does.
Additional capacitive load lowers the frequency of the resonance peak.
« Last Edit: September 15, 2019, 06:42:07 PM by j_flanders »
