Author Topic: Need a help  (Read 733 times)
MaxPayne0
Need a help
« on: September 28, 2019, 02:36:25 PM »
Hi!
I am working on a new project.
While I was removing c3 on my Boss SD-1 and I accidently removed the solder pad closest to the edge of the board I think it connects to r6 but its hard to tell they glued it good in that area does anyone know an easy fix for this?
Thanks in advance.
GGBB
Re: Need a help
« Reply #1 on: September 29, 2019, 12:18:58 PM »
The usual way to fix a missing pad is to bend the component lead over and tack it to the trace, or run the lead to a connected component and tack it to there. Check what the other C3 pad connects to to figure out where the missing pad should connect.
