Author Topic: Behringer SF300 (BOSS FZ2 clone) chainsaw mod?!  (Read 1286 times)
iainpunk
« on: November 09, 2019, 05:46:08 PM »
i have gotten the SF300 almost a year ago from my brothers girlfriend.
i really like the sound but there is the problem of the unusable trebble control (at least in my opinion).
when  full boost, it boosts everything above 800Hz with 2.2dB/Oct, and when it full cut, it cuts everything above 175Hz with -3dB/oct.
honestly i prefer it when its in the middle, or just below it, so the trebble response is flat
i was looking at the board and realised that i have  easy access to every point i need to if i want to replace the passive part with a gyrator, or two...
enter the HM2 by boss, its a classic, and i love it, especially with every control cranked, so i thought it was a great idea to put the gyrator circuit on a mod board and replace the cap and resistor with the chainsaw guts (there is a lot of space in the enclosure), and thus combine two worlds, the DOOM/sludge and the DEATH/GRIND worlds...
does anyone have objections before i DESTROY PLANET EARTH with this SONIC NUKE??!??, or ehm.... does anyone have suggestions what i can improve upon on my idea before i do something stupidly evil like this??!??
, grts, iain
half man - half snail - 6 feet to scale - Snail man's - not frail - He's been - to jail - snail man is fuccing real
『snailpilled』
Fancy Lime
Re: Behringer SF300 (BOSS FZ2 clone) chainsaw mod?!
« Reply #1 on: November 10, 2019, 05:55:32 AM »
Sounds Like a great Idea! Please report back on the result. I've had the same feelings about the FZ-2 treble knob, when I tried it many years ago and stupidly didn't Bus it.
Andy
iainpunk
« Reply #2 on: November 10, 2019, 08:48:44 AM »
yeah, ill report back when im done and maybe ill ask my brother if i can borrow his recording setup (he is a rapper, he has a vocal booth is his bedroom)
im so exited, cant wait to be soldering again
『snailpilled』
iainpunk
« Reply #3 on: March 12, 2021, 12:25:12 PM »
its more brutal because its a Zombie thread now
well... that took longer than planned, i first modded some diy pedals with the same ''mod board''/''daughter board'' to see if it would work, and it does, so i finally took on this SMD board, of which i was afraid of fuccing it up...
here's a rough step by step process i took:
1) the first thing was soldering the daugher board, just a simple perf-board, 4 resistors, 2 caps and a BC547, all according to the schematic below.
2) i located the treble pot on the solder side of the board
3) followed the trace off of the middle lug, and found the cap and resistor to ground
4) de-solder those
5) solder wires from the mod board output to the middle lug of the treble pot, the ground to a random ground pad, and the VCC to the red battery lead pad.
6) close the pedal and grind away for days
cheers
『snailpilled』
