Stupid question
Started by whomeno, November 18, 2019, 10:13:25 PM
whomeno
will a regular mono audio amplifier work as a power amplifier?
I would put a pre amp into it.
looking at some of the prebuilt 50 watt
Gear as of now
Gibson 2017 Les Paul Tribute T
Epiphone Les paul Special (upgraded)
Marshall DSL 20 Head
Peavy Valve king 20 W
2 X 12 Cabinet with celestion vintage 30 & celestion G12T-75
And a lot of pedals
mth5044
Would be good to provide more information. Link to what you're looking at?
whomeno
I'm looking to put a power amplifier in a 125b . then have some pre built pre amp pedals to run to it. I built the tiny giant amp and just now modded it to run at 16.8 volts, but would like to find some thing in the 40 to 50 watt range at 8 ohm. more like the exh magnuim 44 pedal.  I have a marshall dsl 40 cr and a peveay valve king 20 now but looking for a pedal.
Gear as of now
And a lot of pedals
Do you have a link to the amplifier module you're considering? That's what mth5044 was asking.
antonis
Also, what exactly means "stuip"..??  ::)
whomeno
Gear as of now
And a lot of pedals
Analog amps like that one will require sufficient heat-sinking ti dump the heat created by higher power,  Can you achieve that in a 125B?  I have my doubts.  I suspect that the EHX units are all class D amps with switching power supplies, rather than analog.
I picked up one of these last summer for around $10-12. https://www.parts-express.com/tpa3116d2-2x50w-class-d-stereo-amplifier-board-with-volume-control--320-699  You will note that the heat sinking provided does not permit any sort of thermal coupling to a larger heatsink or the wall of an enclosure, implying that it doesn't need more than is provided, except maybe some decent ventilation.
For your power and size requirements, class D is likely what you want.
whomeno
#7
Mark,
Would this fit in a 125b?
Could I just use 1 output?
If so what would I need to do with the
Other one?
Gear as of now
And a lot of pedals
Here's your answer.  I placed the amp on the back plate of a 125B enclosure.  As you can see, plenty of room for an input and output jack, and power jack.  As for whether one can run only one channel,and do so safely, I leave that determination to others.  My own hunch is that you may need to terminate the unused channel.  On the other hand, there ARE single-channel amplifiers of this type available, which sidesteps the problem.
whomeno
Gear as of now
And a lot of pedals
Ben N
#10
Yup, class D is the only way to do what you want (AFAIK) and works fine, but you may have to pad down or limit you preamp's output. This is no tube amp, and any saturation of the power amp is going to sound bad, so you have to keep it linear--it is just like reamping. Of course you can simulate power amp saturation in the preamp. I've got one of these
in my practice rig (works into a cab or headphones), and it's class D power--no problem, sounds great, just all the dirt comes from the nutube preamp or upstream.
whomeno
Gear as of now
And a lot of pedals
stallik
Quote from: whomeno on November 19, 2019, 03:21:02 PM
would something like this be good? it is only 35 watt.
https://www.banggood.com/TDA8932-35W-Digital-Amplifier-Board-Module-Mono-amplifier-Low-Power-Consumption-p-1460337.html?rmmds=search&cur_warehouse=CN
I'd say that this would be good for something. Whether it's good for what you want? Probably but maybe not. At this price, what's the harm in trying one?
I've played with many boards of this type and they've all worked though I tend now to take the wattage as pure marketing - I'm used to valves. The  power supplies I've built for the boards end up being much bigger than the board itself
Ben N
#13
If you're used to tubes, I'd say half would be optimistic. I seriously doubt you can get the useable volume of a Princeton (15W) out of this. Remember, these things are only good up to the onset of distortion, IOW pretty much the opposite of a tube amp. Also, their protection tends to kick in if you work them hard, and they - just - shut - down (and come back to life after cooling down). So I'd say for practice/living room playing, this would be plenty. Add a drummer or bass player, probably not.
Also, as RG Keen, never tires of pointing out, a power amp is pretty much a power supply with a few extra parts. Powering this little gem with 24v@2A will cost a multiple of the amp itself.
