Little rebel amp bypass
Started by whomeno, November 10, 2019, 07:25:52 PM
whomeno
Hi Guys,
I am building some little rebel amps from the bought pcb V10.
What I would like to do is add a switch in to bypass the clipping diodes ( D1-D2) on the pcb for a cleaner sound.
I would use a dpdt (on/on) switch and  on one end I would add the 3mm led and the other end to bypass the led, How would I connect it to the pcb to do this? or can't it be done.
Gear as of now
Gibson 2017 Les Paul Tribute T
Epiphone Les paul Special (upgraded)
Marshall DSL 20 Head
Peavy Valve king 20 W
2 X 12 Cabinet with celestion vintage 30 & celestion G12T-75
And a lot of pedals
thetragichero
one connection goes to each hole for d1
whomeno
will this setup give a clean sound on the diode side?
Gear as of now
And a lot of pedals
thetragichero
clean-er, probably. louder as well it'll give three options: two different types of clipping due to the differences in forward voltage drop between leds and silicon or germanium diodes and center will be no clipping but louder. it may overdrive later stages
whomeno
ok sounds good which diodes would you suggest? would I leave D2 empty?
Gear as of now
And a lot of pedals
thetragichero
yes d2 leave unfilled
whatever leds you have for the leds. for the other diodes whatever cheap silicon 1n4148/1n914 etc. you could also experiment with asymmetrical clipping for the silicon: two going one way, one going the other
whomeno
Gear as of now
And a lot of pedals
