Author Topic: Little rebel amp bypass  (Read 2291 times)
whomeno
« on: November 10, 2019, 07:25:52 PM »
Hi Guys,
I am building some little rebel amps from the bought pcb V10.
What I would like to do is add a switch in to bypass the clipping diodes ( D1-D2) on the pcb for a cleaner sound.
I would use a dpdt (on/on) switch and  on one end I would add the 3mm led and the other end to bypass the led, How would I connect it to the pcb to do this? or can't it be done.
« Last Edit: November 10, 2019, 07:28:31 PM by whomeno »
Gear as of now
Gibson 2017 Les Paul Tribute T
Marshall DSL40cr
Peavey valveking2
thetragichero
Re: Little rebel amp bypass
« Reply #1 on: November 10, 2019, 08:17:48 PM »
one connection goes to each hole for d1
whomeno
« Reply #2 on: November 10, 2019, 09:07:05 PM »
will this setup give a clean sound on the diode side?
Gear as of now
Marshall DSL40cr
Peavey valveking2
thetragichero
« Reply #3 on: November 10, 2019, 09:35:06 PM »
clean-er, probably. louder as well it'll give three options: two different types of clipping due to the differences in forward voltage drop between leds and silicon or germanium diodes and center will be no clipping but louder. it may overdrive later stages
whomeno
« Reply #4 on: November 10, 2019, 09:39:47 PM »
ok sounds good which diodes would you suggest? would I leave D2 empty?
Gear as of now
Marshall DSL40cr
Peavey valveking2
thetragichero
« Reply #5 on: November 10, 2019, 10:01:29 PM »
yes d2 leave unfilled
whatever leds you have for the leds. for the other diodes whatever cheap silicon 1n4148/1n914 etc. you could also experiment with asymmetrical clipping for the silicon: two going one way, one going the other
whomeno
« Reply #6 on: November 10, 2019, 10:54:58 PM »
ok Thanks
Gear as of now
Marshall DSL40cr
Peavey valveking2
