Author Topic: Old School  (Read 793 times)
Old School
« on: November 13, 2019, 02:58:40 PM »
Hey Guys
Ben N bought this circuit to my attention in a recent thread.
Ever willing to learn I'd like to understand how it all work better.
In a true Kipper style thread I'll post up the drawing I found.
Googles great innit.
Then I'll attempt to explain what I think I see and how I imagine the circuit "Stamps" (ref R G Keen) interact.
There will be some mistakes, laughs hopefully and most of all some learning.
Here goes strap in.
The drawing
"Duck_Arse
otherwise, you might end-up with SOIC or gullwings, for surface mounts."
Re: Old School
« Reply #1 on: November 13, 2019, 03:08:57 PM »
What I think  see
Centre top
555 chip +-18V charge pump. Surely there's a more elegant less parts way of doing this.
Middle left
N channel J fet buffer. I get it. Simple low parts and high input Z
Centre
2N5088 looks very similar to the ea tremolo wobbled bit (technical term)
Q1 here
http://www.generalguitargadgets.com/pdf/ggg_eat_sc_improved.pdf
Then there's the starve feature pot which I imagine introduced more resistance to ground between the emitter and gnd.
Centre right
2N5088 phase shift oscillator
I can see the J fet on the output of the lfo doing wobble duties as it does the same in the above ea tremolo.
Brb needs more coffee.
"Duck_Arse
Re: Old School
« Reply #2 on: November 13, 2019, 03:12:20 PM »
My reaction to basically everything 8)
I'll stick around, nowhere else to be :)
"I'm not sure what "serious design flaws" you see. Does it explode or poison your dog?" - PRR
Re: Old School
« Reply #3 on: November 13, 2019, 03:29:20 PM »
Pull up a pew Nathan your more than welcome.
So I also see the fet below the PSO which presumably goes open when activated by the opto isolator. I'd hazard a H11F1 not sure I haven't looked into it yet.
Bottom left
I see what looks similar to the dyna comp peak detector but with op amps.
I kinda like this portion of the circuit (no surprise there. I'm sure a version will pop up in a future design tbc.)
Obviously the peak detector is controlling said opto.
Thanks guys.
Chip in if you wanna come along for the ride.
"Duck_Arse
Re: Old School
« Reply #4 on: November 13, 2019, 03:49:22 PM »
"Duck_Arse
samhay
Re: Old School
« Reply #5 on: November 13, 2019, 04:16:25 PM »
Edit - spoiler warning. Rich, it you're trying to work this out for yourself, my apologies. Don't read on.
It's a tremolo that uses a JFET as a variable resistor.
The demo here shows what everything does:
https://www.youtube.com/watch?v=Se_grzo9QzM
In your/Madbean's schematic the switch is drawn strangely, but is an on-off-on connected to the LDR (it's not a photoFET). The peak detector sets the resistance of the LDR, which switches in parallel with the depth or speed control so you get a 'dynamic tremolo'.
Starve changes the bias point of T1 to add dirt.
Re: Old School
« Reply #6 on: November 14, 2019, 05:22:06 AM »
Heres a clearer pdf
http://www.madbeanpedals.com/projects/_folders/VFE/pdf/VFE_OldSchool.pdf#page=1&zoom=auto,-13,792
I thought the ldr went to a j fet. Not so It appears.
1    How should ldr be wired please? Is that the switching?
on1 off on2
on1 to 6k8?
off not connected
on2 to 470 Ohms
2    what is the function of the ldr? how does that work. Curious.
Certainly looks like a magnavibe type circuit might work with this too by replacing Q1 with another led ldr combo and the wobbled T1 replaced with a concertina splitter arrangement.
3    Is it really worth having the charge pump?
Can it work from just a split supply +9V, 4V5, 0V?
And btw is Vr = +18V? Not familiar with 555 charge pumps.
Thanks guys
Rich
"Duck_Arse
Re: Old School
« Reply #7 on: November 14, 2019, 09:31:13 AM »
Heres an idea for a vibrato along the same lines unverified as yet..
edited to add output cap, good catch Stephen. Thanks
« Last Edit: November 14, 2019, 09:54:17 AM by Kipper4 »
"Duck_Arse
Re: Old School
« Reply #8 on: November 14, 2019, 09:47:20 AM »
yule want to add a blocking cap before the output level pot.
"Awww you're lookin' good, baby."
"I wanna tell you a story, every man oughta know."
Re: Old School
« Reply #9 on: November 14, 2019, 09:54:38 AM »
Thank you mate.
"Duck_Arse
Ben N
  • Total likes: 351
  • Ben N. - really! Now Israel, once Baltimore
Re: Old School
« Reply #10 on: November 14, 2019, 10:21:24 AM »
Yeah, my understanding was that it's a tricked out EA trem.
Re: Old School
« Reply #11 on: November 17, 2019, 09:00:17 AM »
Who needs old school when you can have new school
A bit of a work in progress
Enveloped tremolo
Drawing update since the led driver was drawn wrong.
Also the tap tempo was ineffective so removed
« Last Edit: November 18, 2019, 04:30:25 AM by Kipper4 »
"Duck_Arse
Ben N
  • Total likes: 351
Re: Old School
« Reply #12 on: November 17, 2019, 09:17:42 AM »
Noice!
