+1 for IC2-A Vbias but -1 for decoupling cap(s)..
(MAX DC gain is unity for each of mixing signals so there is no need for DC unity roll-off due to cap on gain branch..)
but you have 4 times DC, not just once.
10k resistor and 10k trimmer in series is 20k, having that parallel 4x is only 5k.
look at what the opamp does with the Vb as s non inverting gainstage. having 5k and 10k in there would give a gain of 3, thus putting out 3*Vb, which is well above the output threshold.
a solution is lowering the voltage on that particular input to Vb/3.
i propose 15k and 33k to replace the bottom 47k resistor of the Vbias voltage divider, and putting the node between the two resistors to the (+) input of the opamp
cheers, Iain
