Author Topic: Aion Rangemaster Biasing  (Read 2002 times)
willienillie
Re: Aion Rangemaster Biasing
« Reply #20 on: February 16, 2020, 04:27:44 PM »
hFE 45 is low for a Rangemaster.  Change the pot from 10k to 20k (22k, 25k), and I bet you'll bias better.
cnspedalbuilder
« Reply #21 on: February 16, 2020, 08:41:22 PM »
Go back to stock values 68k and 3.9k. Set trimmer to zero ohms or jumper it.  Pick the base resistor, raise value, see what that does, lower value, see what that does.
Here is a Japanese transistor viewed from the bottom.
Mozz, thanks that fits with the datasheet I saw, so it looks like the orientation is right. By Base resistor, do you mean R1 on the schematic (currently 470k)?
cnspedalbuilder
« Reply #22 on: February 16, 2020, 08:57:13 PM »
One more silly question; What is the actual voltage being produced on pin 5 of the TC1044 ?
What voltage does your meter measure it at ?
So before I was testing the circuit with a battery, but this time I checked with my 9V OneSpot. voltage at pin 5=-9.49, Collector voltage=8.99.
Does the Range pot affect the bias?
Thanks everyone:
Base Voltage: ~ -136mV
Emitter Voltage: -86mV
Antonis and Mozz, I can try those steps, but is it unusual that it's not able to bias with the values in the build doc?
if you sling a 470k resistor to supply, and a 6k8 resistor to ground, the midpoint will sit at about 0V13. .
I keep thinking about this. It seems like the base voltage should be around -1V, right? Something doesn't add up here.
willienillie
« Reply #23 on: February 16, 2020, 10:13:21 PM »
Just to be clear, I'm talking about the volume pot ("Boost" in the schematic you posted).  It serves as the collector resistor, and totally relates to bias.  I got the idea of the larger value pot from RG, I think it's somewhere in this sideways .pdf:
http://www.geofex.com/article_folders/rangemaster/atboost.pdf
It worked for me when I was building one with a similar transistor.  I guess I probably used a 25k pot, since that's more common than 20k or 22k, in the US at least.  That rangemaster is long gone, sold to a friend.  I built another for myself with a 2SB175, hFE around 70, and low leakage.  It biases up nicely with the stock circuit values.
« Reply #24 on: February 17, 2020, 08:48:48 AM »
What?? A component tester can get confused between C, B, & E?!?!? Interesting!
OK the transistor is labeled 2SB77. Duck Arse, it does not have a tab or a dot. This appears to be the datasheet:
http://www.datasheet39.com/PDF/824089/2SB77-datasheet.html
It says it has a "collector mark" but I'm not sure what to look for. There is an A (or isocelese triangle, not sure which) inside a circle on one side.
I'm not 100% sure but it appears that the C and E are switched relative to what I see on the datasheet.
 the few Hitachi ge's I can scope here have B in a circle over the collector, but the one Matshushita here has a circle and something hovering, indicating ..... nothing, really. but go with the image posted by mozz, that is the only triangle [pin layout] you need worry about.
Thanks everyone:
if you sling a 470k resistor to supply, and a 6k8 resistor to ground, the midpoint will sit at about 0V13. if, however, you were wanting to fit a 470k and a 68k, your base voltage junction would sit at about 1V14 instead. check very carefully your colour bands.
the circuit shows 470k and 68k. this tells the base to be about 1.14 V. if the base is not at that voltage, one of the resistors is wrong [your measure with a correct oriented trannie would suggest 470k and 6k8], or the transistor is ..... not right in some way. I'm not smart enough to say what the wrong connectioned voltages would be.
"cordwood has no ilks."
"He seemed like a nice bloke" - official statement, Ministry of Truth.
why not show us the circuit diagram?
cnspedalbuilder
« Reply #25 on: February 17, 2020, 01:10:14 PM »
Can y'all help me decide the best next step? I have been getting suggestions to tweak resistor or pot values to try to get the biasing in the zone. It sounds like you are saying that is a doomed approach because there is either something wrong with the resistor values at the base or the transistor orientation is off.
Here are the possible steps to try, starting from least invasive to most likely to destroy things given my limited desoldering skills:
1. Replace either R1, R2, or R3 with sockets and experiment with different resistor values until the bias voltage comes out right.
2. Desolder and remove the transistor and check the base voltage with transistor removed.
3. Desolder and remove the 10k boost pot and try higher pot values.
In case it helps with the decision, here is another datapoint--when I measure resistance on the meter, the resistor values do not look right when they are in the PCB, but the color bars on the resistors look like they are the right values and at least R1 measured right when I pulled it out of the circuit. I don't know why the effective resistance looks different in the circuit.
Big Monk
« Reply #26 on: February 18, 2020, 07:47:17 AM »
From Aion:
"Germanium transistor: Any PNP germanium transistor with a gain (HFe) between 65 and 100 will work here. The exact model is not important (and even varied in the original unit)."
Looks like your issues, as I believe a few have said already, are purely biasing issues. Your transistor gain is too low for this circuit. I would grab a new transistor or tweak the bias resistor values and/or the Boost pot to get things in line.
One last thing to keep in mind: Steve from Small Bear describes those as being unsorted raw stock, and it looks like you got one that was pretty low for a Rangemaster. A good thing to do would be to breadboard the circuit and determine what (if any) combination of bias resistors and boost pot get you the right voltages then put those values in the circuit and box it up.
How did the pedal sound?
« Last Edit: February 18, 2020, 07:52:02 AM by Big Monk »
“We are what we repeatedly do. Excellence, therefore, is not an act, but a habit.” Aristotle
"Beneath the bebop moon, I'm howling like a loon, for you..." Marc Bolan
« Reply #27 on: February 18, 2020, 08:18:32 AM »
It's a Japanese NOS PNP transistor from Small Bear specifically tested to be suitable in a Rangemaster
if this is one of the japanese for rangemaster dealios, can you show a photo of the page that came with the transistor please? it should have some values written on it. (when I looked his site last night the included page was showing an npn on the circuit dia. THAT could confuse a few people.)
as to your possible steps - remove the transistor from the board. measure all the resistor values [POWER OFF, obvs] just to check, again. rebend the transistor legs to the match that mozz image. plug the transistor into your breadboard with the small bear resistor values listed. measure your e-b-c voltages.
and as Big Monk sez - How did the pedal sound? doesn't matter the numbers if the toans are there good.
Big Monk
« Reply #28 on: February 18, 2020, 08:38:00 AM »
I think is it Duck:
http://smallbear-electronics.mybigcommerce.com/2sb77-hitachi/
Looks like one of those unsorted lots Steve has with goodies if you get the right one.
« Reply #29 on: February 18, 2020, 09:19:26 AM »
cnspedalbuilder
« Reply #30 on: February 18, 2020, 11:10:24 AM »
I was thinking it was this one ....
http://smallbear-electronics.mybigcommerce.com/transistor-the-rangemaster-pnp-japanese/
Duck is right that is the one. It was came with that Dallas Rangemaster sheet and is listed as: "PNP JAPANESE", Rb=47k, Re=4.3k. The plastic component bag says "79" and then below that "L=257". I have no idea what the writing on the packet means, maybe 79 is the Hfe that Steve measured? The value I got was much lower (45), but maybe that's because I am using a cheap component tester.
but I did initially try the values that Steve suggested on the schematic, and those did not work. With those values, the Rangemaster sounded terrible. There was signal loss, not boost. I haven't tried plugging it in after doing all the changes I've described above, so I can certainly try that. I'll also desolder that transistor  :icon_cry: and try it on the breadboard.
Thanks to everyone for their help so far.
Big Monk
« Reply #31 on: February 18, 2020, 11:18:38 AM »
Ok. I read one of your other posts where it seemed like you were referencing another transistor.
It was what came with that Dallas Rangemaster sheet and is listed as: "PNP JAPANESE", Rb=47k, Re=4.3k. The plastic component bag says "79" and then below that "L=257". I have no idea what the writing on the packet means, maybe 79 is the Hfe that Steve measured? The value I got was much lower (45), but maybe that's because I am using a cheap component tester.
Something doesn't seem right there. Historically, I've found my at home Hfe results show slightly higher than Steve's "Bare Bones" numbers. I've always just chalked this up to minor differences in test rig and if they are close i trust Steve's values.
I think the best route is to go back to square one and check your circuit. What were the bias voltages with Steve's recommended values?
+1 on the breadboard. I'm an advocate of doing all testing on the breadboard before wiring everything up and making it permanent. Troubleshooting a circuit after everything is already in the board/box is always a pain in the ass.
cnspedalbuilder
« Reply #32 on: February 18, 2020, 11:29:27 AM »
Thank you, again, I can't say whether the Hfe value from my component tester is necessarily accurate, and it's not clear that the 79 on the packet is Steve's Hfe measurement, but he did put in resistor values suggesting that this would be a good transistor for the traditional circuit. The transistor was sitting in my garage for a year or two though, so maybe that, or the soldering, could have affected performance?
I figured that since i was using a PCB and a pre-tested transistor, this would be a cakewalk! I had no idea that the rangemaster could be so high maintenance! OK, will pull the tranny out and try it on the breadboard.
Big Monk
« Reply #33 on: February 18, 2020, 11:38:10 AM »
79 is the Hfe and L = Leakage.
Did you socket the transistor, or apply heat directly to the leads? If the latter, did you heat sink the transistor? It's not all that hard to damage a transistor when soldering it into a circuit.
Slowpoke101
« Reply #34 on: February 18, 2020, 03:40:26 PM »
I was going to ask the same question. Germanium transistors are very easy to damage when soldering. I've seen some transistors installed with full lead length (insulated with tubing ) in an attempt to reduce heat conduction whilst soldering. Doing this can introduce some other fun issues that may drive you nuts.
I have some of these transistors stored away so I grabbed a couple of them and bread-boarded the circuit. No problems at all. The only adjustment done for biasing was to vary R2 (68K ). R2 was substituted using a 50K trim-pot and a 22K resistor. HFe of one transistor (AC132 ) was near 90 and the other (AC125 ) was near 60. The emitter resistor was just the standard 3k9 that is commonly used. The Boost (volume ) pot was a standard 10K.
I suspect that your transistor is very unwell.
Edit: At some point you asked if it was normal to get different resistance readings when the resistors are in circuit. The answer is yes, when measuring the in circuit resistance of a resistor your measurement will usually read lower than the value marked on the resistor. Accurate measurement is only possible when the resistor is out of circuit (or at least one end lifted out of the board ). Also never try to do a resistance measurement on a powered circuit. If you don't damage your meter by doing so, the readings that you get will be meaningless and the small amount of voltage coming from the meter will cause the circuit to behave very strangely.
« Last Edit: February 19, 2020, 01:05:03 AM by Slowpoke101 »
cnspedalbuilder
« Reply #35 on: February 19, 2020, 01:43:21 AM »
Actually I did solder the transistor in directly, could that have affected the Hfe? I kept the legs on the longer side, and I'm pretty careful not to linger on those solder joints, but yes it's possible that it got hot. If the transistor is "unwell" does that mean I should just get a new one or is it still potentially useable with different resistors?
Thanks also for the tip on the meter, I did not know about that, I still have a lot to learn.
Slowpoke101
« Reply #36 on: February 19, 2020, 02:05:15 AM »
I would suggest that getting another transistor would be a good idea. There really isn't anything else that could be wrong. Try to get a tested transistor with a HFe of around 90 to 100 with low leakage - Smallbear should be able to help. I think that you got your original from there.
It is very easy to heat damage germanium transistors. Their gain and leakage properties change dramatically. See if you can find a suitable socket at Smallbear (a good quality socket ) to save having to solder the transistor. Be aware that the socket may fail after 10 to 15 years - usually corrosion or metal fatigue of the contacts.
From my quick experiments with my bread-boarded circuit and trying a few different transistors, it is worth having one of these effects....Damn, now I have yet another build to put on my list.
Big Monk
« Reply #37 on: February 19, 2020, 07:31:48 AM »
...I still have a lot to learn.
Don't worry, we all do!
See if you can find a suitable socket at Small Bear (a good quality socket ) to save having to solder the transistor.
I'll second this. I usually stick a dab of hot glue on the transistors once I find the one/combo I like.
From my quick experiments with my bread-boarded circuit...
Another key point: ALWAYS breadboard first. When I was first starting out, I gave myself fits trying to troubleshoot circuits that were already hardwired/soldered into the board. A breadboard is such an essential and cheap purchase that lets you get the circuit how you want it before you fire up the soldering iron.
It also gives you a starting reference, i.e. "I had it working on the breadboard..."
cnspedalbuilder
« Reply #38 on: February 21, 2020, 01:41:06 PM »
I haven't yet finished breadboarding because work has been crazy but I did manage to desolder and test the transistor again. I was getting fairly different results on the component tester when I put it in, then popped it out and retested. The best and most consistent result was HfE=90, so that is good I think? Maybe the connector on the component tester is a little wonky? Or is it possble that somehow the transistor is "loose" and jiggles in and out of alignment with pressure? Maybe that is silly, I don't really know how these metal tube transistors look inside.
Big Monk
« Reply #39 on: February 21, 2020, 01:54:20 PM »
When you say "component tester", what do you mean exactly? You really can't just pop a Germanium transistor into say a multimeter based transistor tester because the leakage found in the Germanium unit skews the results.
If you finish breadboarding the circuit using the Small Bear transistor and the circuit sounds good, you'll know you made an error somewhere when wiring up the Aion board.
