Over/reverse voltage protection circuit trial
Started by composition4, February 17, 2020, 09:00:01 AM
composition4
Hi all
I'm just finalising a design and really want to protect from overvoltage and reverse voltage, there's some ICs with 12v max ratings. Trying to keep it relatively simple but obviously there's always tradeoffs. I've simulated the below circuit; based on RG's "A cheap - and good - polarity protector", but with an added zener/resistor/NPN for the overvoltage side of things.  I won't get a chance to physically test it for a week or so, but can anyone see any problems with it... or is there a more elegant way?
Jonathan
composition4
Also, I realise I should probably add a diode between ground and the base of the leftmost transistor for reverse polarity protection of the transistor
